compatible fail safe
Hi all i have the earthquake 3.5 with the 2.4 ghz radio ive tried dynamites fail safe and it wasnt compatible , guess what im asking is what fail safe is compatible with my EQ 3.5
I was told by my local hobby shop that if you're running a 2.4 gig radio a failsafe is not needed ....I don't how accurate this is but I've had my Earthquake since May and haven't run one and haven't experiencedany problems as of yet.
i havent had ant problems either but ive heard all the horror stories about them going out of control id rather be safe than sorry .
I use this one with my Earthquake.
http://www.urchobby.com/proddetail.php?prod=03028
If your batteries run low on your transmitter, even if it's 2.4, you're going to wish you had a fail safe.</p>
thanks i had bought a dynamite fail safe but couldnt get it to work right kept going full throttle took it to my LHS and he couldnt get it to work right either but ill give the red cat one a try and see what happens thatnks for the info
ORIGINAL: ClammyBallz
NH
ORIGINAL: Valgath
we also have the RedCat version here,
http://www.rctoysnh.com/catalog/prod...oducts_id=1728
I bought a couple of these a while back for all my redcats. They work great on both my 2.4ghz and AM/FM systems.
$5.99 shipped
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
$5.99 shipped
ok an update bought the red cat fail safe does the same thing as the dynamite one , when i program it it goes to full throttle .
Are you doing it correctly?
Hold the program button THEN reverse on your transmitter.
Make sure to plug-in the failsafe where your throttle/brake servo is located(i'm guessing chan 2).
yes im doing it correctly per instructions
<span class="Apple-style-span" style="font-family: Arial, Helvetica, sans-serif; border-collapse: collapse; ">Set up instructions:
1.<span></span>Remove throttle servo plug from receiver.
2.<span></span>Plug male failsafe plug into receiver where servo was plugged into, plug servo plug into female plug of failsafe.
3.<span></span>Do not start car, put transmitter and car power on,<span></span>apply full braking on transmitter, press and hold set button on failsafe for 5 seconds.
4.<span></span>Test failsafe by turning transmitter off and leaving car power on, if failsafe is set up properly, brakes will be applied fully when transmitter power is turned off.<span>
I think its cause im using a futaba s3003 throttle servo if that matters at all , ive tried reversing the wires on one end and that gave me no response in throttle .<br type="_moz" /></span></span><br type="_moz" />
well just got back from running my EQ and i lost control of it it went full bore out of control lol lucky thing tho it went into a ditch and flipped on its lid now if i could find a working fail safe for it id be golden , on to futher probs ive replaced battries in my radio and my reciever and it still acts like it wants to go out of control ive inspected the antena its fine , before it done that i ran 5 tanks of fuel thru it and was on the 6th when it happened .
TN
Hi I had the same problem then I found out the 2.4GHz dsm-2c radio that comes with the earthquake has a built in failsafe. Just turn both your transmitter and truck on then find the small black button next to the red LED light on the receiver. Apply full brakes, or your desired failsafe position and hold, then with a small screwdriver or hex wrench push the black button on the receiver and hold until the red light starts to blink {3-5 seconds}. Then release the button THEN the brake and it should be set. Test it by turning your truck and transmitter on applying full throttle {engine not running} then turn your trans. off and the failsafe should activate just like external failsafes.hope this helps
ORIGINAL: nitronut423
ORIGINAL: Valgath
ok an update i went and bought a new factory red cat reciever at my LHS i havent fully tested it yet but there is no throttle twitching in my servo , so far i think it was the reciever like i said i havent fully tested it yet and thanks for all the help and info
ORIGINAL: Valgath
TN
I have a earthquake 3.5 2.4GHz with the Fly Sky GT/ DSM-2C radio and reciever that I bought three months ago. Although neither Redcat or FlySky tell you this when you buy it,it does have a built in failsafe. I tried several external failsafes and none would work,I e-mailed Redcat and then I was told that my radio system had a built in failsafe. You use the bind button on the receiver to set the built in failsafe. See my previous post for instuctions,after folowing these steps. my Earthquake 3.5 2.4GHz no longer goes to WOT when the transmitter is turned off, it goes to the position I set with the built in failsafe.I've had trouble getting some people to believe me because there is no mention about this feature in either the truck or the radios' manuals. But if your truck has the same radio package as mine it has a built in failsafe. Hope this is usefull to somebody else, I don't want anybody else to waste hard earned money on a failsafe that is not needed like I did.
