harding the diff gears
Hi,
I have read alot about the diff gears going bad on the redcats and i was wondering if anyone knew what the gears are made of? cast steeel or cut from stock>
I know you can heat treat metal in an oven and with a torch and you can also dip steel in liquid nitrogen for a few days to harden up steel.
Would thiss work? if my gears go out on my EQ 3.5 i will try to heat treat the new ones.
Think out of the box
Hardening metal requires expensive machinery, not a thing you can do at home. You can "surface Harden" steel at home by heating it till its glowing red then quenching it in oil. But this process only hardens the surface and leaves the rest of the metal untouched.
The liquid nitrogen treatment (cryo treating) you mentioned doesn't actually harden metal. It actually realigns the molecules of the metal into their natural state, strengthening their bond to each other. Machining, casting, forging, etc can push or pull the molecules apart, decreasing the strength of their bond to each other. Cryo treating doesn't strengthen metal, it makes it as strong as it can possibly be after you've cast, forged, machined and/or heat treated it.
ORIGINAL: nlovern
Hi,
Hi,
ORIGINAL: nlovern
I havent opened it up to check the diffs yet. Its new. Do I need to?? I have a EQ 3.5. Saving up money to get fuel and oils,ect...
Hi,
Nathan here. My redcat EQ 3.5 is new. I also found a local hobbie shop. Yeahhhhhh.
One other thing. I put batteries in everything and i noticed the throttle servo likes to humm and stick open. i can hit brake for a second and it closes. can i fix this?
thanks
thanks
ORIGINAL: nlovern
Hi,
thanks
Hi,
thanks
ORIGINAL: nlovern
Hi,
I dont get the horn thing your talking about. hope i dont sound lame.
Nathan
Hi,
Nathan
I horn is the arm or horn that you screw into the metal gear on the top of the servo, somtimes the spline can strip out I would pull that off and turn the pwr back on and see if the servo acts the same.
