Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
brand new truck
Old 09-15-2011, 03:07 AM
ehroof
Default RE: brand new truck
try a spring from a pen, the retractable type.
Old 09-15-2011, 03:39 AM
bkbajan
good idea.
ORIGINAL: ehroof
Old 09-15-2011, 05:27 AM
bkbajan
your idea worked perfectly,thanks alot
ORIGINAL: ehroof
Old 09-15-2011, 12:52 PM
bkbajan
day 2 went pretty well..
only one issue,i realized fuel coming from the glow plug hole while the car was running.
any idea what would cause that?
Old 09-15-2011, 01:04 PM
ehroof
Did you put the washer on the plug before you put it in or did you make sure the plug was tight?
Old 09-15-2011, 01:08 PM
  #31
bkbajan
yes and yes. it did that on the last tank that i ran
ORIGINAL: ehroof
Old 09-15-2011, 02:01 PM
  #32
ehroof
hopefully its not stripped but i would try a new glow plug before you jump to that conclusion.
Old 09-15-2011, 02:03 PM
  #33
bkbajan
ok,are there any seals in tht area tht may be bad?
im gonna try taking the engine out soon
ORIGINAL: ehroof
Old 09-15-2011, 03:11 PM
  #34
ehroof
The only thing on the glow plug is a washer that seals it... its possible the washer is not good..... dont put any thread compound or sealer there, it will make problems.
Old 09-15-2011, 05:20 PM
  #35
bkbajan
how do i deal with a rounded hex screw?
got 3 of 4 engine mount screws from the underside out..the last one got rounded.
any tips?
ORIGINAL: ehroof
Old 09-15-2011, 06:31 PM
  #36
bkbajan
gonna have to bring the dremel out..
Old 09-16-2011, 02:45 AM
  #37
ehroof
i usually use the dremel, just make a slot in the screw head and use a regular screwdriver to take it out. One of the only uses i ever really found for a dremel besides body trimming and smoothing out.
Old 09-16-2011, 03:34 AM
  #38
billymare
Make sure the 4 head bolts are tight... I had that happen to me...
ORIGINAL: bkbajan
ORIGINAL: ehroof
Old 09-16-2011, 06:53 AM
  #39
nitrosportsandrunner
nitrosportsandrunner's Avatar
i use my my drill and drill the head of the screw till the head is gone. then you pull the motor off and use a pair of pliers to turn the shaft of the screw till it comes out.
Old 09-19-2011, 02:26 PM
  #40
bkbajan
do these trucks experience brake fade or is it just the crappy servo?
Old 09-19-2011, 05:15 PM
  #41
ehroof
not really unless your brake is dragging and its glazing the pad.
Old 09-19-2011, 05:40 PM
  #42
bkbajan
ok,do u have any experience with the steel brake disc?
is it really any better than the composite one?
ORIGINAL: ehroof
Old 09-19-2011, 05:58 PM
  #43
ehroof
yes, much better, i still have a small stash of old style metal disc/fiber pad setups. The composite can round out sometimes where it meets the drive cup or they can actually melt, i have had the composite/plastic brake discs actually melt to the metal shoes on a few of my rc's, my hpi rs4 3 would always lockup on the track until i upgraded the disc.
Old 09-19-2011, 07:36 PM
  #44
bkbajan
does redcat have a fiber pad?
or can i piece together a set-up from other manufacturers ?
ORIGINAL: ehroof
Old 09-20-2011, 05:34 PM
  #45
ehroof
an rs4 3 evo may fit
Old 09-26-2011, 10:44 PM
  #46
bkbajan
i changed my servos..and now the truck doesnt respond to the controller.
any ideas?
Old 09-26-2011, 11:20 PM
  #47
bkbajan
i realized i had the channels crossed.
throttle and brakes work...but no steering, its stuck all the way to the left now..
Old 09-27-2011, 02:47 AM
  #48
ehroof
probably the steering servo is not good, just swap the 2 plugs for the servos on the receiver, the throttle will control the steering and the steering will control the throttle, if it still does the same thing then the servo is no good. before you go thru this, take the servo horn off the servo and see if it moves without the linkage hooked up to it.
Old 09-27-2011, 04:48 AM
  #49
bicyclebob
man, sorry to hear about your problems.  i just got my caldera 3.0 in yesterday and i'm going to take it out today to start breaking it in.  i hope i don't run into the kind of problems you are having.  good luck bro.
Old 09-27-2011, 08:32 PM
  #50
bkbajan
fixed it,the servo wasn't at center when i installed it.
