Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
cooling head
Old 12-21-2006 | 10:15 PM
Default cooling head
Does anyone know where i can buy a new cooling head for a volcano stx?
Old 12-21-2006 | 10:18 PM
AllAboutFunHobbies's Avatar
Default RE: cooling head
HPI. I could tell you somewhere else but I promised I wouldn't say it any more, lol.
Old 12-21-2006 | 10:19 PM
lol
Old 12-21-2006 | 10:32 PM
I rebuilt one with an HPI .15 cooling head, I had to adjust the spacer to bring the compression up but it worked great. I've also found it easier for me to just make my own on my lathe and mill that way i can have the compression where ever I want it, but that's not feesable for most people, lol, just a thought though, if you happen to have a lathe and mill lying around.
Old 12-22-2006 | 07:42 AM
{GBI}Harryball's Avatar
What crap, someone comes in looking for a part and no one can answere him. WOW. www.redcatracing.com go there it might cost more and the shipping will be more, but at least you can get the part. Also if you want take this guys name AllAboutFunHobbies put a www in front or it and a .com behind it and order from him.
Old 12-22-2006 | 08:31 AM
mozzzy_2000's Avatar
what engine is in that nitro? bet you there would be one that would fit other than purchasing another stock head from redcat.
Old 12-22-2006 | 08:35 AM
ORIGINAL: mozzzy_2000
.18 vertex
Old 12-22-2006 | 08:42 AM
4 or 6 bolt head?
Old 12-22-2006 | 09:02 AM
4 bolt, i think this one would work: http://cgi.ebay.com/ws/eBayISAPI.dll...0208&rd=1&rd=1
but if you can buy one from someone on the forum, your better off
Old 12-22-2006 | 08:40 PM
the problem with my cooling head is that i must have messed up the threads where you screw in the glow plug. i havent taken the head off to examine it yet. is there a way to fix the threads or should i just buy a new head? i havent touched the truck in months. i've been running my revo alot.
Old 12-22-2006 | 08:53 PM
you could try to retap the head, i dont know what size it is though
Old 12-22-2006 | 09:17 PM
email allaboutfun I think he has replacement heads.
Old 12-22-2006 | 09:23 PM
i think he said they were going on vacation for 2 weeks starting the 22nd
Old 12-23-2006 | 01:30 AM
yeah I reckon other heads would fit. Have a look at these. Yes, pricey but just about the best engine heads available. I reckon one of these would fit.
http://cgi.ebay.com.au/HPI-Nitro-Sta...QQcmdZViewItem
http://cgi.ebay.com.au/HPI-18SS-RS4-...QQcmdZViewItem
http://cgi.ebay.com.au/OS-18-TM-Nova...QQcmdZViewItem
http://cgi.ebay.com.au/OS-18-TZ-Nova...QQcmdZViewItem
Old 12-23-2006 | 12:50 PM
you could try the os.18 cv-rx head it might fit on our engines since that motor is a direct fit in our cars
Old 12-23-2006 | 10:12 PM
i took off the head today and the threads looked fine.
Old 12-23-2006 | 10:14 PM
so what exactly is the problem your having with your head? Is it leaking where it screws down?
Old 12-23-2006 | 10:31 PM
i thought i might have messed up the threads where the glow plug screws in to the head. It was hard to screw the glow plug into the head. so i checked the threads and they look fine. so everythings ok.
Old 12-24-2006 | 08:09 PM
ORIGINAL: fordguy2001
It's screwed, trust me very shortlly it will not be fine. I've had that happen a few times on these heads, it's that crappy 5 way wrench, I think it doesn't hold the glow plug right. I won't know exactally what parts I have from TST till I get back, but I think there was a head in the stuff not sure though.
{GBI}Harryball
The reason no one said Redcatracing is because you can't buy engine parts from them, only whole engines, chances are you will never be able to. Also for the rest of you I have rebuilt a few .18 engines with HPI .15 engine parts before. Con Rods pins are the same, con rods are shapped different but the pin ends mic to a perfect fit, sleeves work pistons work, and so on, heads also.
Old 12-24-2006 | 09:05 PM
Wes, do you sell the head?
Old 12-24-2006 | 11:37 PM
ORIGINAL: ehroof
LOL, Wade, it's wade, lol. I'm not sure till I get the final Invoice slip with the stuff, on the original quote I think there was one or two, but I'm in Buffalo, NY right now and the info is on my PC in Texas. He should be able to use a HPI .15 head, will work fine but will need to purchase a shim set with it. Should be able to get it from tower or check out www.nitrohouse.com I think that's the URL.
Old 12-24-2006 | 11:40 PM
lol, close enough no???
Old 12-24-2006 | 11:44 PM
lol. so do you guys get along now, cause last I checked you guys hate eachother. finally the fight is over....i think??
Old 12-25-2006 | 09:30 AM
ORIGINAL: ehroof
Sort of. I guess, lol.
Old 12-25-2006 | 10:29 AM
at least it had a W, it could have been worse
