HELP!! 2nd gear shift help
When i full throttle my redcat tsunami i just bought, right when it shifts to 2nd gear, it boggs down real bad and sometimes dies. Does anyone know what i should do??
are you in it full throttle when it shifts and then it boggs? or are you just getting to speed when it shifts and boggs? More than likely fuel either way but if you slowly change the mix and go over a full turn lean or rich and no change throw it away and buy a Honda..................oops I mean either try and adjust the clutch (see other thread for buggy or car shifting problems) or replace the assembly. [&:]
