redcat volcano upgrades
#52
RE: redcat volcano upgrades
you need a 2 speed trans from the tsunami and a 2 speed clutch bell but you need an hpi clutch bell, the 13/18 one, its not any good believe me, its still too high geared.
#56
Hot plugs are run in small block engines or engines that run lower content nitro. Big blocks run colder plugs. I you run a small block engine with lets say 10% nitro you need a hot plug. If you run a small block with higher content like 33% you need a cold plug.
#60
i need to make the hole were the hex nut fits on the rim i had a hex nut spin out and round the hole out now i need to make it hex shaped again
#65
the best way to get a decent shine from your body is spray with wd40 and wipe it in , i dont know if you can find someplace that would make custom rims, maybe a machine shop that works with aluminum, try a search on google, try custom rc rims or custom radio control car rims
#66
CO
ORIGINAL: ehroof
put a smaller clutch bell in it, like a 12 tooth that should give you much more torque.
#67
TX
Custom RC rims are very very expensive. I've made a few in my machine shop for some guys that like to have these kinds of parts on there show trucks, but your looking at $100 or more for two rims.
This is one place:
[link=http://www.rc-parts.com/]http://www.rc-parts.com/[/link]
I believe these guys will do Custom Machine work if you blue print it:
[link=http://www.acncm.com/]http://www.acncm.com/[/link]
Crazy nut is another CNC place, but looks like there website is under construction, here's the link anyway for future reference:
[link=http://www.crazynutracing.com]http://www.crazynutracing.com[/link]
You can find other by searching for custom nitro RC wheels.
This is one place:
#72
ok, you can take the plastic hex adapters (12mmstock ones) and put 14mm hex adapters on it then mount the traxxas rims and tires to it. i am almost 100% sure, i will check and see since i have some 14mm hex adapters from a tmaxx laying around.
#74
i dont have a price bro, i am not a hobby shop or dealer. i will let you know if it works and if it does i will take a picture to explain it to you.
