Volcano Tsunami Wheely Contest
TX
Ehroof had a good idea that we have a Wheely contest. I am gonna take it a step farther and will award the winning prize, the contest will start Sept 1 and run through to the end of Sept. Hopefully Clermont will make this a sticky. Videos will be posted on the RCU Redcat forum in this thread at the end of Sept Clermont and I will decide who has the best and longest wheelies.
The Idea and What it Will Take to WIN
The idea is to hop up your Volcano or Tsunami to the point that it can ride a wheely.
What Will it Take to Win
The longest and best wheely with out using a wheely bar will win.
Rules and Regulations:
1.) All Volcano or Tsunami vehicles MUST be 4 wheel drive and must have all 4 axles and center axles installed. You must submit proof on the video, that you have all drive shafts installed and working.
2.) No weight reduction by removing front end parts. Equally no adding weight to the rear. You must prove that there is neither one of these being done by showing it in the video before you run the car.
3.) All vehicles must be running in the videos the body ON.
4.) There are no limitations to what you can do with the engine, gearing, exhaust system, radio system or the fuel system.
5.) All videos must be viewable and somewhat clear.
6.) When posting your video make a list with links of the parts you used and what you did to make your car do a wheely.
Non-Eligible Entries
1.) Dealers are not allow to participate as eligible entries, but may post videos of there wheelies.
2.) Any entries whe think or suspect of cheating will be disqualified.
I think that's about it to keep it fair. Start making your videos this weekend and seeing what it might take to get your Volcanos and Tsunamis riding wheelies.
Best Part, What Is the Winning Prize
The winning prize will be the New Ultra Wide Tsunami.
Ultra WIde Tsunami Specs:
Description: Tsunami Ultrawide; Aluminum A-Arms and 2 inches wider than regular Tsunami; Tuned Pipe; 1/10 Scale Four Wheel Drive Stadium Truck Features: VX-18 Taiwan Engine, Ball Bearing, 2 Speed transmission, and a low-profile body.
Engine VX 18
Engine Manufacturer Vertex
Transmission Two-Speed
Gear Ratio 1:5.84 (High) - 1:8.58 (Low)
Drive System Four Wheel Drive
Radio System Two Channel A.M.
Length 400mm
Overall Height 160mm
Wheelbase 275mm
Front Shock Length 95mm
Rear Shock Length 95mm
Front Tires Block Tread
Rear Tires Block Tread
Tire Diameter 150mm
Wheel Diameter 105mm
Differential Type Two Bevel Gear
Chassis Type 2.5mm 6061 Aluminum Alloy
Brake Type Single Steel Disc
Fuel Tank Capacity 75cc
Suspension Type 4 Oil Filled Shocks
UPGRADES ALUMINUM A-ARMS FRONT AND REAR TOTAL 2 INCHES WIDER THAN TSUNAMI (1 INCH EACH SIDE)
UPGRADES TUNED ALUMINUM EXHAUST
LET THE VIDEOS BEGIN!!!!!
Engine VX 18
Length 400mm
Wheelbase 275mm
Tire Diameter 150mm
