Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Pull Start Installation??
Old 01-24-2008 | 05:30 AM
Default Pull Start Installation??
I am getting ready to swap out the broken pull start on my Tornado BB and am curious the best way to do so. The inside 2 screws look impossible to get to. Does anyone have any tricks or should I just pull the engine??
Old 01-24-2008 | 06:09 AM
Macanan's Avatar
Default RE: Pull Start Installation??
You have to pull the motor, no way around it sad to say.
Old 01-24-2008 | 11:04 AM
Not a problem, I just wanted to make sure before I went and pulled the engine.
Old 01-24-2008 | 11:21 AM
willashcroft's Avatar
unfortunately you have to mesh the gears, which isnt a problem, but i dont like doing it as i sometimes wrongly mesh them.
Old 01-24-2008 | 12:29 PM
Does anyone know what pull start the newer VX-18's use?? Redcat has them with a 1" bolt pattern and 1 1/4" bolt patten.
Old 01-24-2008 | 01:52 PM
the newer ones are the 1" pattern
Old 01-24-2008 | 06:05 PM
I'm not too familiar with the bb I have a volcano, but if you can, I find it easier to just pull the whole rearend out as an assembly. You can then get to the inside screws much easier and don't have to mess with the mesh on the motor.
Old 01-25-2008 | 08:29 AM
just draw circles around the screws for the engine before u take it out so that u can line if up eaisly
Old 01-25-2008 | 10:12 AM
5lagd's Avatar
you might want to scribe the aluminum plate where the screws are. permanent marker sometimes gets worn off after running.
