2.4GHz Radio
2.4GHz Radio
We are almost done testing some new 2.4GHz radios that will show up in some of our RTR vehicles this year.
So far they are working great and the price is hard to beat.
We will have them in 2 offerings.
A 2 Channel and a 3 Channel.
More info to come later.
Darin
Darin
My Feedback: (-2)
RE: 2.4GHz Radio
wich models would you be thinking of putting them in? the 5th scale line could use a radio, but that would bring the price up as its an ARTR(servos only). would they be sold seperatly as well?
BC, CANADA
RE: 2.4GHz Radio
Hi,
I have the Tornado EPX and I upgraded it with this exact radio, the FlySky FS-GT3. It's got tons of features and being a newbie with these digital radio's I'm not sure what the settings do but I hope I can learn how to use all the settings soon.
I only know how to use the Trim and sub trim. What is end point? DR? ABS, ST Delay, TH delay, etc.
RE: 2.4GHz Radio
I tested this radio. its so cool and easy to use menu
However there is a delay in control response when car gets more than 50 meters. that makes it not a useable radio at the moment
End points are used to limit the servo movement to a specific point. name tells clearly that is, where do you want servo to end moving or stop moving. so you can tell servo how far it should travel either right or left before it reaches to its end points
DR is dual rates, that is soften or sharpen the servo travel response in each direction. how far it should move. there is a confusion and mix up between end point and DR. you can check definitions online
ABS is braking system maybe it makes servo jitter for good braking so tires won't jam
ST Delay is the delay set and TH Delay for throttle, you can set the delay for your controls
Cheers
Ali
Cheers
Ali
NY
RE: 2.4GHz Radio
im gonna be ordering a redcat but not for sometime and i was wondering what models this radio will come with or is that not decided at this moment? im gonna be ordering a buggy or MT and while your here Ali what Buggy and what MT are your best Bashers that can take some abuse.
RE: 2.4GHz Radio
Hi
as per my own testing and bashing the following models stood well for abuse
Volcano SV 1/10 scale Nitro Truck. Now available with S30 Models better 18 Engine
EarthQuake 3.5 1/8 Scale Nitro Truck
BackDraft 3.5 1/8 scale nitro buggy
Plus in electric
Aftershock 8E and backdraft 8E Specially took much more abuse and bashing
Cheers
Ali
Plus in electric
Cheers
Ali
BC, CANADA
RE: 2.4GHz Radio
Regarding endpoint, when I set the values to 0, 100, it doesn't go in reverse. However when I put 15, 100, reverse works. So what should the value be? 50,100?
Also I don't think my brakes are working. When I push brake my car tends to just slow down and then after a sec it goes in reverse. I'm wondering if it's my TX or do I have to program my Novatech ESC.
