Sumo Hop Ups
Is there a good reference for doing these hop ups? The motor was easy, I'd like to replace the bushings with bearings now.
Never done it, and didn't know if there was a video or some point of reference. Thanks ! |
RE: Sumo Hop Ups
Best place to look is the exploded diagrams in the manual. For the bearings you'll pretty much take the entire truck apart.
RE: Sumo Hop Ups
Roger that :D I've got the first ones installed, and trying to get it back together, it's kindof a pain to get this through the bearing holes.
Other than that, yes 6 screws and taking some things off to get the bushings out and bearings in. I think putting it back together is the hardest part so far. Thanks ! |
RE: Sumo Hop Ups
ORIGINAL: rootbeerslop Roger that :D I've got the first ones installed, and trying to get it back together, it's kindof a pain to get this through the bearing holes. Other than that, yes 6 screws and taking some things off to get the bushings out and bearings in. I think putting it back together is the hardest part so far. Thanks ! The only things I have questions about now are: 1. If you tighten down the arm screws, the shocks don't go up and down very easily. Took me a sec to get that right :D Does anyone thing the Aluminum Shocks help this little guy ? I heard the 180 motor and the bearings were the best upgrades. Motor is definitely louder than the stock one. I'll see how fast it goes in a bit. 2. I tested all the bearings by hand before reassembling, and they seemed to be smooth. When I test drove the car it still stops pretty fast, doesn't seem to "glide" in comparison to the previous parts. Should you put WD-40 on the wheels or anything to help with the smoothness? <br type="_moz" /> |
RE: Sumo Hop Ups
You have the motor meshed to the spur gear wrong or you have some binding in the diff. Check the diffs first. Remove the motor and see how it rolls if you push it with your hand, if it rolls hard or stiff, then something is too tight in the diff or you have some screws too tight in the diff case. If it rolls smooth, then put the motor back in and re-set the mesh of the motor pinion and the spur gear. It shouldn't sound any louder than the original motor. Also make sure you don't have the throttle trim knob set in the wrong position.
RE: Sumo Hop Ups
ORIGINAL: AllAboutFunHobbies You have the motor meshed to the spur gear wrong or you have some binding in the diff. Check the diffs first. Remove the motor and see how it rolls if you push it with your hand, if it rolls hard or stiff, then something is too tight in the diff or you have some screws too tight in the diff case. If it rolls smooth, then put the motor back in and re-set the mesh of the motor pinion and the spur gear. It shouldn't sound any louder than the original motor. Also make sure you don't have the throttle trim knob set in the wrong position. <br type="_moz" /> |
RE: Sumo Hop Ups
ORIGINAL: rootbeerslop ORIGINAL: AllAboutFunHobbies You have the motor meshed to the spur gear wrong or you have some binding in the diff. Check the diffs first. Remove the motor and see how it rolls if you push it with your hand, if it rolls hard or stiff, then something is too tight in the diff or you have some screws too tight in the diff case. If it rolls smooth, then put the motor back in and re-set the mesh of the motor pinion and the spur gear. It shouldn't sound any louder than the original motor. Also make sure you don't have the throttle trim knob set in the wrong position. <br type="_moz" /> Put the back on and it seems to run smoother as a whole. It still stops kinda fast, but that is probably just me expecting it to roll farther because of bearings. I think it should be good. Thanks for your advice ! This is a fun little truggy. <br type="_moz" /> |
RE: Sumo Hop Ups
I have Radline oil filled shocks on mine. Seems like they're more for show than anything but who knows. I have 2 extra sets with the aluminum control links, pm me if you're interested.
Radline, if you aren't familiar, was a very similar truck sold at Target for a while. |
