pull start
i have clendra 3.0 when i get it started it runs for abount 5-10 secounds then the pull start will spend and clicks and dies some times if you pull it out alittle it wont die thank you
RE: pull start
maybe the 1 way bearing that the pull start connects to is going bad?
The pull start itself should not prevent a motor from running. Any idea what the temps of the motor are after 5-10 minutes? |
RE: pull start
most of the time it does it the motor is cold but if i hold it out a little ican run in the back yard for about 5minthe trunck is new it only been played with abount 6 times for maybe 3-4 min at a time then it you can see the pull rope hadle spin half way round and click and die when you start it again it spins again and dies thanks for your help
| All times are GMT -8. The time now is 12:15 PM. |
