volcano with trx3.3 upgrade
1 Attachment(s)
I recently blew the stock engine in my volcano s30 and couldnt find much info on anyone who has done an engine upgrade so i went about it myself. If anyone is interested in doing this i have included pictures and a stock list of parts i used, it was a very easy install and the truck is now very fast and actually wheelies!!!
STOCK LIST:
this upgrade was well worth it i have had about 20 tanks of fuel so far with not breakage of any kind, eventually i do expect to break something or everything but it is well worth the cool factor<br type="_moz" /><br type="_moz" /> |
RE: volcano with trx3.3 upgrade
1 Attachment(s)
I had forgotten that i changed how the springs were on the throttle linkage so i put up new pics of the linkage below i also put a pic of the spacer i used between the linkage to servo connector and servo arm
wow, nicely done.
It must wheely like crazy! |
yes it does and if anyone can tell me how to post videos i can post a couple
ORIGINAL: buckhoule yes it does and if anyone can tell me how to post videos i can post a couple |
[youtube]http://www.youtube.com/watch?v=x1uPXWUrfhU[/youtube]
here is one video, not very good but there is more to come<br type="_moz" /> |
you hardly got on the throttle, yet its clean that truck is very fast!
Thats a cool truck set up you have. I have a Volcano S30 also. With a GS.21 in it. Bought a used .21 engine and installed it on mine. Finally was able to order a new bell pinion for it to get a better gear in it. I changed out the rear shocks to Traxxas Stampedee rear shock on mine. Only cause the pipe i have on it was right where the shock was. Only other bad thing was it burns through the fuel really fast. My sons electric truck which out last mine. I order a 100cc tank that is from HPI and am in the process of putting it back together. Will have get some pics up later.</p> |
1 Attachment(s)
Here are couple pictures when I first installed the GS.21. i will get more this evening with the new tank in it.
That looks real nice it must fly, how do you like those shocks are they a good improvement over stock?
I also just put a sealed 2 speed for a backdraft 3.5 in my truck I'm getting 45 out of it now but still can go up A couple teeth on the clutch bell, let me know how the tank fits thAt you bought I'd like more run time too lol <br type="_moz" /> |
ORIGINAL: bpohl I order a 100cc tank that is from HPI and am in the process of putting it back together. Will have get some pics up later.</p> |
1 Attachment(s)
I like the way it handles with these shocks on the back. Its balanced pretty good right now. I am running a 18T bell. I can almost turn it on a dime and it will pick up th inside wheel when I gas on it. I have another set of shocks which i am going to try on the front and see if I can get this thing balanced real good. We have a local track so trying to get it tuned in to race. I looked at going bigger but could not find a tank I liked that was the right dimensions, trying to keep as much as the stock look as possible. Here are the updated pictures with the tank in. Only other thing i have done is upgrade the steering servo to a 9kg servo and installed a piece of aluminum on my servo saver so the truck will steer better. Yes I know i could of gone to the aluminum servo saver but I liked this better;)
