Engine Quits when I squeeze throttle
I have a nitro Caldera 3.0 recently I had to send the engine back for repair/replacement I just got it back, this was the first time I've completely taken out the engine and disconnected it from throttle rods etc. so I got the engine in and from what it seems like I connected everything properly but, I'm having two issues.
1 - major issue whenever i squeeze the throttle the engine quits. it starts up easy in a few pulls, and will stay start but, as soon as i squeeze throttle engine quits. 2 - this was worst at first but, after a little bit of tweaking of needles it seems to have been mostly resolved but, issue still there. not sure if it's due to needle adjustments or just after 1 or 2 tanks the engine warmed up. what was happening at first was that the caldera would start up and just sit there at idle speed then after about 20-30 second the engine would start reving faster and faster until the engine quit. Now, normally if your lsn isn't set correct then your engine will start reving immediately and then quit but, in this case it doens't do it immediately it takes like 20-30 seconds and the wheels start turning because of the reving and if i even try to tweak the throttle trim (it's at 0) or press the brake it has no effect. Now after a tank or so of fuel of it just staying start and of little adjustments to needles it seemed to have minimzed now it will do short quick bursts of rev and tires turn a bit then go back to idle but, it doesn't rev high anymore so engine doesn't quit at idle. I took some pics of the throttle rod connections and I made two short 10 second videos, one of the #2 issue and then the other video is of me pressing the brakes. I want to confirm if I connected the rods correctly since to me it looks like when I press the brake that the throttle mechanism is not moving enough isn't it supposed to move in the opposite direction of if you were to increase throttle? you can see me pressing the break but, it's only moving very slightly, like a slight jiggle. Here's the links to pics/videos: http://dl.dropbox.com/u/38834766/201...2016.41.25.jpg http://dl.dropbox.com/u/38834766/201...2016.41.54.jpg http://dl.dropbox.com/u/38834766/201...2014.43.29.mp4 http://dl.dropbox.com/u/38834766/201...2017.11.00.mp4 Thanks <br type="_moz" /> |
RE: Engine Quits when I squeeze throttle
try leaning both the needles out a tiny bit and see what happens.
i already tried that, didn't work. i had to lean out hsn since i'm breaking in engine and it says to lean it out 1/12 at tank 2, i tried that with both lsn and hsn, didn't work. lsn is just about set perfect if i adjust it just a little too far in one direction it will start reving on it's own, and in the other way will be difficult to get it to start
from the pics did i connect the throttle rod back correctly? what about the video of how unresponsive the brakes are, is that how it's supposed to be?
<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">well i guess i may have resolved the issues, i just kind of messed with the throttle gear manually pushed it back/forth and then it started moving fine, i can press brakes and that throttle gear will move like it should.</span><br style="font-family: Verdana, Arial; font-size: 13px; " /><br style="font-family: Verdana, Arial; font-size: 13px; " /><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">i'm able to accelerate now and engine won't every time but, is still sometimes, i think what the issue might have been was that the fuel tubing was suck between the engine and where the fuel tank sits, and even though it was getting fuel after i primed it yesterday. today i was trying to prime it and the fuel wouldn't go through the tubing, so i took the fuel tube out of that stuck area and when i primed it in one pull the fuel immediately went through, so maybe that's the reason it was doing those short revs since there was an issue with air flow and fuel mixture.it doesnt seem to be doing that anymore.</span><br style="font-family: Verdana, Arial; font-size: 13px; " /><br style="font-family: Verdana, Arial; font-size: 13px; " /><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">the engine still has quit on me three times now once when i pressed throttle but, not immediately like when i'm accelerating fast. i'm not actually driving it yet since i'm at my shop (not allowed here) it's just sitting on a block, not sure if that's the reason the engine is quitting when i get home tomorrow i will do actual driving with it. it still has improved since yesterday at least it's not quitting every time i throttle. maybe after a few runs or more breaking in it wont' do that anymore</span>has other suggestions would be appreciated.
ORIGINAL: rcenth well i guess i may have resolved the issues, i just kind of messed with the throttle gear manually pushed it back/forth and then it started moving fine, i can press brakes and that throttle gear will move like it should. i'm able to accelerate now and engine won't quit, i think what the issue might have been was that the fuel tubing was suck between the engine and where the fuel tank sits, and even though it was getting fuel after i primed it before, today i was trying to prime it and the fuel wouldn't go through the tubing, so i took the fuel tube out of that stuck area and when i primed it in one pull the fuel immediately went through, so maybe that's the reason it was doing those short revs since there was an issue with air flow and fuel mixture. the engine still has quit on me twice once when i pressed throttle but, it has improved since yesterday at least it's not doing it all the time. maybe after a few runs or more breaking in it wont' do that anymore or if anybody has other suggestions would be appreciated. <br type=''_moz'' /> |
thanks for that.
oddly enough the engine is not stalling at all when i brake, even at idle it doesn't quit, so i hope idle screw is set properly. only when i accelerate fast sometimes, if i'm accelerating slow it's still fine but, it's not stalling every time anymore when i accelerate, like I said it's also on a block right now and not actually driving it not sure if that's a reason, will see tomorrow. about lsn i already tested that a bit and as you said 1 hr in each direction is enough to see changes, i think it's at about the right setting since if I turn it about 1 hr one way then the engine won't start, or quit after i remove the glow plug. if i do it the other way then it will rev and tires move on it's own. so i think it's at about where it should be. hsn is rich, fuel is spewing out of exaust. i'm turning it 1/12 each tank as it says in the instructions. i'm not really sure if i should be "breaking it in" like this while it's sitting on the block and I can't actually drive it, i'm on the 3rd tank so have turned in hsn 1/12 each time, was just trying to start it and get engine warmed up for tomorrow and make sure everything was setup correctly. i think after this tank i'll leave it as it is. ORIGINAL: Dads like rc too ORIGINAL: rcenth well i guess i may have resolved the issues, i just kind of messed with the throttle gear manually pushed it back/forth and then it started moving fine, i can press brakes and that throttle gear will move like it should. i'm able to accelerate now and engine won't quit, i think what the issue might have been was that the fuel tubing was suck between the engine and where the fuel tank sits, and even though it was getting fuel after i primed it before, today i was trying to prime it and the fuel wouldn't go through the tubing, so i took the fuel tube out of that stuck area and when i primed it in one pull the fuel immediately went through, so maybe that's the reason it was doing those short revs since there was an issue with air flow and fuel mixture. the engine still has quit on me twice once when i pressed throttle but, it has improved since yesterday at least it's not doing it all the time. maybe after a few runs or more breaking in it wont' do that anymore or if anybody has other suggestions would be appreciated. <br type="" /> |
well i dont know i guess there is something wrong, again i should probably not be doing this on the block and actually driving it but, i've done this with the shockwave before reved it on a block and engine didn't quit like this. maybe the 2nd gear is not set correctly? if it's happening when it's accelerating maybe it's trying to switch gears? i made a video of what's happening, here's the link: https://dl.dropbox.com/u/38834766/20...2012.36.35.mp4
damn now the problem with the brakes is happening again edit: backed out throttle
edit: backed out throttle rod a bit from linkage cup and brakes working again for now<br type="_moz" /> |
You can't break it in on the block. You need to put a load on the engine or it will just rev out. 1st tank at idle is ok. Some even like to run two tanks at idle, but trying to run it on the block is a waste. You'll never get the engine hot enough for sleave expansion.
ok got it, will just wait until tomorrow
well i'm just starting to get aggravated now, i was bringing the caldera back home with me after the shop closed i accidently left it powered on (just the power switch, it wasn't started) and then when i almost got home it started making this strange sound i turned it off but, when i got home and was getting ready to power it on and start it, i turned the power switch to on and then that sound started again, the sound is coming from the throttle gear is that the servo under there? now that gear doesn't respond to throttle or brakes. i made a video of the sound it's making and me trying to throttle and you can hear what kind of noise it's making - http://dl.dropbox.com/u/38834766/2012-05-27%2018.45.14.mp4<div>
</div> |
i guess it looks like the servo went bad? i'm going to order another to replace it, since i can't figure out what else it could be
Fill out the warranty form
Ok, I went ahead and filled out warranty form. Though I still went ahead and order it as well since I was putting in my weekly order and didn't want to wait as it could take 2-3 days to get the claim approved and I didn't know for sure if it would be covered under warranty. I asked them in the claim form if they approve the claim if they can just credit me back. I don't know if they do this or not, I took the risk but, it's not a big deal I just don't want to wait more time, was really looking forward to doing some runs tonight :( I've been getting teased all day lol i've only been able to start it and not run it at the shop haha<div>
</div><div> </div> |
Remember, buy two. One for the repair, one for the parts bin
good thinking! if they approve the warranty i'll just tell them to send the replacement and put that aside and then i have this one on the way
incase this problem happens with somebody else, the issue was the glow plug that's the reason the engine was dying when i throttled, after changing the glow plug that doesn't happen anymore
| All times are GMT -8. The time now is 04:41 PM. |
