RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   ESC amperage question (https://www.rcuniverse.com/forum/redcat-racing-support-427/11607889-esc-amperage-question.html)
GuidoDoc 12-13-2014 06:53 AM
I bought a new Tornado EPX Pro. As I was looking at some of the details in the spec sheet I noticed that the motor amperage is 56A but the ESC is a 45A rating. Won't the motor fry the ESC if it draws more amps then the ESC can handle? This came with a 7.2V NiMH 1800mAh battery.
zackS30 12-13-2014 05:04 PM
I believed that means the motor is able to handle 56 continuous amps.
RustyUs 12-14-2014 03:10 PM
Your ESC is rated at 45 continuous amps and has a burst current handling of 220 amps or 260 amps depending on either the WP-S10C or WP-S10E ESC that is in the vehicle.
zackS30 12-14-2014 04:30 PM
I think the confusion was the motor says 56a but the ESC says 45a
GuidoDoc 12-14-2014 07:46 PM
Thanks for the help guys. The confusion for me was also that the motor was listed by its MAX amperage at 56amps while the ESC was listed with its continuous amperage of 45amps. I had to dig but found that the ESC can handle a peak amperage of 220amps. I knew it didn't make sense. None of the documentation from Redcat was very clear or complete.
