RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   2 wheel vs 4 wheel (https://www.rcuniverse.com/forum/redcat-racing-support-427/4057903-2-wheel-vs-4-wheel.html)
chopper22980 03-20-2006 10:43 AM
2 wheel vs 4 wheel
would making my volcano 2 wheel drive make it faster then 4 wheel?and would it be easier or worse to steer?ive seen video on 2 wheel drives,not redcat products and they seem to fair better.maybe its just my eyes seeing things.any help on this would be great.thanks guys.
nitrosteve22 03-20-2006 12:00 PM
RE: 2 wheel vs 4 wheel
IMO four wheel drive is superior in pretty much every way. I dont think you'd see a major improvment in top speed but if you removed all components associated with the front wheel drive your acceleration would improve (less weight and rotating parts). Although I've herd of people running in to serious traction problems when just removing the dogbone that connects center to front differentials or remove the dogbones that connect from the front gearbox to the tire hubs. It would work if you converted the front hub things to a spindle type like off of a stadium truck,and remove the front gearbox and dogbones and got a majority of weight off the front tires you'd have something similar to a Stampede or sportmax that would work just fine.
Hope this helps ;) .
chopper22980 03-20-2006 01:09 PM
thanks for the info.i think i will just leave it the way it is.i dont wanna cause any more damage then i have too lol.
shamelessbill 03-20-2006 05:03 PM
I've been running mine as a 2wd since the first good wreck. You will burn up rear tires on the pavement.
You will also see an improvement in excelleration and top end. If your running street only its good. In the dirt you get no traction from all the torque in the ***** end.
You be the judge.
SB
