RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   just a question (https://www.rcuniverse.com/forum/redcat-racing-support-427/4213029-just-question.html)
fordguy2001 04-27-2006 12:35 PM
just a question
i need to know the size of a screw. it goes behind the gear box on a universal joint. the screw holds the universal joint to the driver shaft for the front tires to work. right now i have rear wheel drive. does anyone know that im talking about?
chopper22980 04-27-2006 01:23 PM
RE: just a question
I think its a m3*3 grub screw(set screw).If its where I think you are talking about.
fordguy2001 04-27-2006 10:10 PM
RE: just a question
i did a quick fix. i found a small screw laying around so i used it. so far its holding.
fordguy2001 04-29-2006 09:47 AM
RE: just a question
how big are the m3*3 grub screws? i'd post a pic of where the screw needs to go but i dont know how.
mozzzy_2000 05-07-2006 11:29 PM
RE: just a question
yep I think it is also a 3mm grub screw from memory. Should be able to source that at your LHS.
Cheers
