tornado xp....please help
i just bought the tornado xp. after the break in stage i was running it pretty hard and noticed a couple things. for some reason it doesnt want to switch to 2nd gear, i was also considering the possibility that it was in 2nd gear and wasnt going back to first as it was moving pretty fast and slow to the start. also, the manual said 2-3 tanks for break in, so i started giving it a little more about half way thru the 3rd tank....was this to soon? ive also had problems keeping it running, it likes to stall when im giving it gas and even occasionally when im not. im new to this, so any help would be appreciated, thanks....steve[&o]
RE: tornado xp....please help
Well, first off, I have a volcano STX, but I think you have troubles with your fuel, top-speed, and idle mixtures. I,however only know this on account of just getting over this same problem. They will require a lot of tinkering, but its worth it in the end. GOOD LUCK!
Also, in case it won't idle, take the engine off the bottom plate, and check the clutch spring to see if it is broken. This can be done at any hobby store for a reasonable price. I am only going off of my car, but hey, they're the same brand, how different can they be right?
ORIGINAL: dookar i just bought the tornado xp. after the break in stage i was running it pretty hard and noticed a couple things. for some reason it doesnt want to switch to 2nd gear, i was also considering the possibility that it was in 2nd gear and wasnt going back to first as it was moving pretty fast and slow to the start. also, the manual said 2-3 tanks for break in, so i started giving it a little more about half way thru the 3rd tank....was this to soon? ive also had problems keeping it running, it likes to stall when im giving it gas and even occasionally when im not. im new to this, so any help would be appreciated, thanks....steve[&o] |
thanks for the tips guys. i think im running pretty rich right now as i have it almost 5 full turns out and the manual says to run it rich u need only be 1 and a half turns. im thinking this manual sucks by the way. i seem to have the car switching gears finally but it does it as soon as i give it gas, it only wants to stay in first for a second or so then it switches which is way too soon, so im still messing with that. i did however get a new glow plug from my brother, and it is a hot one. bryan, my brother, has a few of the nitro cars and says he thinks that i got a good deal on this car at around $200.00, but he thinks that the manual might be off a bit. like only 2-3 tanks for break in, he says his are from 4-6 on his traxxus and ofna. also, he thinks that the manual for the red cat might be a little off as we are running real rich at 5 full turns out, but any less and u cant even see any smoke coming from it, which it should have. red cat wants to run it at 1 and 1/2 turns, which seems lean. so what do you guys think. im a noob to all of this and wonder if my brother really knows what hes talking about lol.
| All times are GMT -8. The time now is 03:45 PM. |
