RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   breaking in (https://www.rcuniverse.com/forum/redcat-racing-support-427/4358062-breaking.html)
reese_19 06-05-2006 11:24 PM
breaking in
i was in the third tank with my volcano stx and it cut off and when it started i go to hit full throttle just to see something it will cut off
chubbysuncle 06-06-2006 12:11 AM
RE: breaking in
Check the clutch spring. See if it's broken. Check the FAQ thread.
Popper252 06-06-2006 12:29 AM
RE: breaking in
Yeah in the FAQ thread check to make sure all your needles are in the right spot. It sounds like you may be running a little too rich. When you hit full throttle you may be flooding the engine. Or it could be the other way around and when you hit full throttle the engine starves for gas.
Nexous 06-06-2006 08:49 AM
RE: breaking in
More than likly flooding the engine. It happened to me too. was wondering why it died once i started to hit 3/4 to full throttle.
Too much fuel!! engine get too cold when that much fuel is added and cannot egnite future fuel. hence stall.
if you wanted to test the theroy you could find a way to strap your glow starter on and try reaching full throttle again.
lmao. not what i suggest. lol. just my retarted friends idea to keep maximum oil cooling while breaking in a engine.
over kill in my books.
reese_19 06-06-2006 11:47 PM
RE: breaking in
is the volcano stx is they 1 speed if it is can you change it to a 2 speed or thats not a good idea and where is the clutch spring at
bluecaka69 06-07-2006 12:21 AM
RE: breaking in
read posts check faqs thread clutch spring first post
http://www.rcuniverse.com/forum/m_4207842/tm.htm
volcaon single speed
ehroof 06-07-2006 05:32 PM
RE: breaking in
sounds like it running to lean, most of the time an engine cuts out on top end when its too lean.
