Tremor?
Anyone have one of these yet? if so please post what you think. Thanks
RE: Tremor?
Well I bought one from Mark at TST. Ten tanks so far. The only problem is the on/of switch did not work. I just hard wired it:) Redcat is taking care of it.Starts easy, break-in was three tanks.After three tanks it starts to get up and go. Its well built, handles great. I cut the body above the engine to let some heat out. Prime it by putting afew drops of fuel in the carb and its set to go. Its louder then you would think. Great truck for he price, I think ill run it more then my kyosho st. because no down time to charge the batt.
RE: Tremor?
Thats the nice thing about nitros..no charging of batteries. In most cases atleast.
RE: Tremor?
bt123 is the overall preformance any good on the truck????
RE: Tremor?
When its going it winds up fast. I had to seal the carb(2 new orings), header, new zipties on pipe. The pullstart spring gave up today,so Ill have to wait till they get some in. Its kinda hard to get the tune right, (only one screw) too lean and it shuts down at half a tank, too rich and its hard to start.GOOD NEWS IS: No gear problems, it has a slipper clutch!!!Ill check to see if i can get a ps. for the Chaos.
RE: Tremor?
Eric, when will parts for the Tremor be available on redcatracing.com ??
RE: Tremor?
Not soon enough. I've beeen given an ETA of about 4 weeks.
BTW, the Infinity .05 in the Tremor is the same engine as the Toki in the Chaos, so the pullstart will most definitely work. |
