stripped gears help!! :(
What are the gears that the clutch bell turn? I have a volcano stx with stock everything and my engine wasnt tightened all the way and it shifted and stripped that big gear and the small one thats right behind it. the big gear looks like it has a spring behind it i believe. was wondering what are they called and where can i get some better gears?
RE: stripped gears help!! :(
They are part number 08013 differential gears. Make sure on your next set also that the purple spring is tight. They are sometimes loose.
Just tighten the purple nut all the way down on your next set. You can get the gear set from us www.allaboutfunhobbies.com or clearmont motor sports or Extreme Nitro, you can even call me at anytime by going to our contact us page. My suggestion is that where ever you get the gear box from make sure while you have the engine off to replace the Clutch bell and clutch with an HPI 18 tooth clutch bell and a traxxas clutch and spring set if you don't you will be very unhappy in the long run. Also get some Lock tight and lock tight every single metal to metal screw, check all your nuts and bolts through out the car.
get the parts from clermontmotorsports.com, he's a great guy and very reasonable. i ordered every replacement part from him for almost the last year.
True that. Thats where I'll be going from now on.
i dont see the gears no where on either site. can someone liink me plz
anyone know? is the replacement gears from redcat anygood? like is there any better gears i can get that are same tooth but made out of better metal
The gears are ok, I have the same gear set in my truck for the last year, but ya have to change the clutch bell and clutch pads. Hang on I'll give you the link to our site, for the gear set, You said an Stx right?
what about the hpi 17t clutch bell.thats what i put in my SV. i also need new gears
http://www.allaboutfunhobbies.com/volcanostxparts.htm That's the page with the parts you need, If you want them let me know, I'll put a buy it now button on them, I haven't gotten to the Volcanos yet so I just posted the parts you need with no add to cart button. Shipping is $1.75
ya its a stx. The clutchbell doesnt look damaged... just the gear set is... before i go changing the clutchbell i want to get that engine that ehoof was telling me about on another post i put.... but ya
that aluminum clutch bell will warp and tear up your gears again.
could i get a discount then if i buy it all from u? i dont have all the money to dish out atm... for the clutchbell i want good topend but not sacraficing a whole lot of bottom end... dunno what tooth clutchbell to go with... it will be next week dec 20 be4 i can order it... but if u will give me a discount make me up a "cart" and send me the link to [email protected] . what are the clutchpads? i do not see them anywhere..but i havnt taken the truck apart yet either its sittin in the closet atm...
On part #08023 moderate gear set it would be $23.50 on part #08013 Differential Gear Set
it would be $13.75 like I always say if you find it cheaper shoot us the link to look at, shipping should be around $1.25 or some where in that range it will be actual shipping. We will be gone from the 22nd of Dec till the 3rd of January. |
here is the savage clutchbell you wont lose any acceleration with this
http://cgi.ebay.com/HPI-Savage-16-To...em110066587006 |
what tooth is the stock clutch bell?
also, will someone tell me if those 2 gears are the part #08023 moderate gear set or the part # 08013 diff gear set? its the one on the stock stx volcano .. the gears that the clutchbell turn the big one appears to have a spring behind it then theres a little gear on the front of it that turn some more gears. I need those 2 gears. which gear set is it?? i dont want to buy the wrong ones lol...
17
ehoof u know which gear set i need? lol
8033 is the spur gear, comes with the small aluminum gear too.
lol but do i need the spur gear? i dont know which 2 gears theres are.... clutchbell turns this big gear(in which i need) and on the same shaft is the little gear... (need that too) and the little gear turns another gear and so fourth.. but i have 3 different gear sets and i dont know which one i need lol....
8033 is the big gear the clutch bell touches, then there's the small aluminum gear, they are both 8033
i just bought the clucthbell off ebay that u linked me to, whats the procedure in changing the clutchbell out? because i know that theres bearing or so that it spins with.....
its easy enough, take the engine out, you will see a screw at the end of the clutch bell, take that out, pull the bell off, take the bearings and washers out, pay attention to how you took them out, install the new clutch bell the way you took the old one off. make sure you mesh the gears good before you use it again, use a piece of looseleaf paper between the spur and clutch bell.
Thyreaper take a look at the thread [link]http://www.rcuniverse.com/forum/m_4207842/tm.htm[/link] You want to read post #252 it will explain just like ehroof said how to remove and replace the clutch bell. With pictures also.
