RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Install roto-start (https://www.rcuniverse.com/forum/redcat-racing-support-427/5147113-install-roto-start.html)
eldoradomick 12-22-2006 05:10 AM
Install roto-start
guys hows it all going just need some help installing the ROTO STARTER do i have to remove the engine or rear end or is there an easier way?
also i stuffed the diff gears (part # 08013) i already have the replacement but dont know how hard to force everthing to replace it!!!!
cheers
eldoradomick 12-22-2006 05:14 AM
RE: Install roto-start
should ahve said its to go on the Eldorada truck with the .18 motor all standard...... for now:D
zack221 12-22-2006 12:56 PM
i would take the motor out its a whole lot better because you have more room just make sure you get the gear mesh perfect once you put it back in a easier way to do this is to take off the upper plate that is the whole plastic piece that the fuel tank mounts to once you take it off you can see the gears alot better so it helps more with the gear mesh
eldoradomick 12-23-2006 01:51 AM
cool thanks zack will give it a try as soon as i nget rid of these pesky visitors!!
