HELP PLEASEEEEE
I JUST BOUGHT A REDCAT VOLCANO SV. I HAVE IT ON A STAND AND WHEN I START IT ALL IT DOES IS SPIN THE WHEELS REALLY FAST... IF I APPLY THE BRAKES THE MOTOR WILL JUST STALL. PLEASE HELP.... THANK YOU
RE: HELP PLEASEEEEE
You need to check your throttle trim control on your controller and also adjust your idle.
RE: HELP PLEASEEEEE
if thats ok you may have a bad clutch spring refer to this thread on how to replace it http://www.rcuniverse.com/forum/m_4207842/tm.htm very first post also use traxxas 4146x spring it will last longer
RE: HELP PLEASEEEEE
wierd[sm=50_50.gif]. I would say thats a broken clutch spring, cause it dies when you use the brake but becasue of the wheels spinning, I think it is just the throttle trim like he said. hope you get it working.:D
RE: HELP PLEASEEEEE
when you apply the brakes can you look in the carb and see if closes completely when you apply the brake. if so you need to open the idle screw and set the trim more twards center or foreward. if it stay open then you need to replace the clutch spring.
RE: HELP PLEASEEEEE
lol good advice ed, I just sent him a pm and told him the same thing. I think that is what is happening.
RE: HELP PLEASEEEEE
sorry [X(]
RE: HELP PLEASEEEEE
thats ok your the rcgod lol sorry had to throw that in. Just kidding ya. I like it when things go smooth on here. Sure helps :)
RE: HELP PLEASEEEEE
yes my son, things are good here tonight, god has spoken.
RE: HELP PLEASEEEEE
lol:)
RE: HELP PLEASEEEEE
THANKS GUYS... YA IT WAS CLOSING COMPLETLY SO I ADJUSTED THAT BUT STILL JUST SPINS THE WHEELS ALOT AND I ACTUALLY HAD IT ON THE GROUND AND WAS HOLDIN IT... NOT GOOD.. SOME PLASTIC WAS BURNING AND SOME FLEW OUT.... DONT KNOW.. BUT IT STILL RUNS BUT I CANT GET IT TO STOP SPINNING AND NOT DIE. THANKS AGAIN.... IM VERY NEW TO THE HOBBY SO I THINK IM GOING TO TAKE IT TO A LOCAL SHOP TOMORROW...
RE: HELP PLEASEEEEE
yeah sounds like the clutch to me too.
RE: HELP PLEASEEEEE
Is your air filter on? This may sound silly, but I had the same problem when I first started mine and couldn't figure out why. I thought it was the clutch spring...NOPE, tried adjusting the idle scerw...STALLED. I was ready to throw it in the trash, but then (for some strange reason) I put the air filter back on, and guess what... All was good!! The only thing I could think of was that it was getting too much air and running rich causing this to happen. Could this be his problem??
RE: HELP PLEASEEEEE
I hope not! you can seriously screw up an engine in seconds running it without a filter but I hope you already know that. The idle definately shouldn't be behaving like that so if you can;t turn the idle down further I'd still look at the cutch.
RE: HELP PLEASEEEEE
I know that now!! This is my first nitro so I was following the Redcat manual, big mistake. It says to put a couple fo drops of fuel in the carb to prime it, so I did and left the filter off. Anyway, thats all I did and it solved the problem for me. Just a suggestion.:eek:
RE: HELP PLEASEEEEE
AWESOME... THANKS TO ALL GOT IT RUNNNING AGAIN... IT WAS THE CLUTCH SPRING.. QUICK FIX.. BUT NOW I LOST THE FREAKIN NUT ON THE SERVO THAT CONTROLS THE ACCELERATINO AND BRAKE... I GOT TO WAIT TILL TOMORROW AND HOPE THE LOCAL SHOP HAS ONE... N E WAYS... THANKS AGAIN.
| All times are GMT -8. The time now is 04:19 AM. |
