Volcano sv
I am new to the rc world and have a new sv. The truck ran great until my first crash. A small rock got stuck in the diff gears and i replaced the gear box! After that i cant get the truck to start. I have not messed with any settings on the carb. Any ideas would be great!!!
RE: Volcano sv
check the glow plug, take out and put in ignitor and see if it glow.
RE: Volcano sv
It looks like i cigerette lighter does in a car.
RE: Volcano sv
plug is good then, did you fool with any of the needle settings? Did you break it in?
RE: Volcano sv
Didnt adjust any settings at all. I broke it in and ran about 6 or 7 tanks of gas befor i broke it. Prior to the rock in the gears the truck started with only 2-or 3 pulls max. it really ran good!!!
RE: Volcano sv
So i was reading another topic or forum on after run oil. I did put oil in after i crashed and never pulled the plug could this be the problem?
RE: Volcano sv
i dont think so, i am a little stumped, make sure the carburator has a little opening on it when you have the radio and car on, maybe something got a little moved when you changed the gear, did you lake the engine out?
RE: Volcano sv
is it sucking gas into the carburetor?
RE: Volcano sv
So here is what i have found out. After puling the plug and checking for glow. i pulled the cord a few times and tried again. it still wouldnt go. i moved the th trim on the controler all the way open and it started (very high rpms) adjusted down to a slower idel and it died. The only way i can get it to start is if the trim is wide open. i am looking through other threds to see which needel it is i need to adjust unless someone knows off hand.
RE: Volcano sv
yes it is sucking gas but not much
RE: Volcano sv
Adjust your idle screw so that the barrel in the carb is about 1mm open. The idle screw is just below the air filter.
RE: Volcano sv
1 Attachment(s)
heres a pic of the motor it shows which screw is which
| All times are GMT -8. The time now is 02:10 PM. |
