e clips
i am currently changing my spur gear in my volcano sv. HOW THE HECK DO U RE INSTALL THOSE FU**IN E CLIPS!!!!!!!!!!! I already lost two of them . Do i really need to put them back in?? if so, is the part # is 02037?
SOMEBODY PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!![sm=angry_smile.gif][sm=angry_smile.gif][sm=angry_smile.gif][sm=drowning.gif][sm=drowning.gif][sm=confused.gif] |
RE: e clips
usually the best way is with a pair of needle nose plyers, i am not sure about the part number for them, i will let a dealer answer that. and yes you do need them and they are a pain in the a** to put on and sometimes take off
RE: e clips
Don't buy the Eclips on line if you have a hardware store near you. If you haven't lost them all take one with you to the hardware store and ask the dude behind the counter to help ya find that size E-clip, will be WAAAAYYYYY cheaper than buying a bag of eclips on line. But if you can't find them at the hardware store or you don't have one near you the E-clips are 02037 there is 12 to a bag.
RE: e clips
i made you a drawing i know its sloppy but i put it together real quick lol
http://img1.putfile.com/thumb/1/1622181482.jpg |
RE: e clips
All I can say is welcome to the joyous world of eclips!! Gawd they're aweful aren't they? The amount I lost "pinging" across my living room as been many! lol.
Never used needle nose pliers but e-clips are meant to be removed with a small flathead screw driver. Just put a corner of the driver blade in one of the slots and simply twist gently. They should pop off without any trouble and should not "ping" off. Putting them back on just line the clip over the pin & push down with the end of a screwdriver or something similar. The only thing you have to worry about is bending them or damaging them which is easy to do as they end up being useless and fall off if that happens. Above all its a trial & error process and take it from me, the more times you remove e-clips, the easier it becomes trust me. |
RE: e clips
ORIGINAL: zack221 i made you a drawing i know its sloppy but i put it together real quick lol http://img1.putfile.com/thumb/1/1622181482.jpg Hey zack you think your so smart you ever tried to put e clips on a micro t with needle nose Just playin good pic that works like a charm |
RE: e clips
yea i know bluecaka that is one of the reasons i havent bought one is because they are so little and hard to work on since their little
| All times are GMT -8. The time now is 04:11 AM. |
