compatiable 2.2 wheel list
hey yall i'm thinkin about puttin a list together of 2.2 compatiable wheels and tires any help yall can give will be appreciated i'm trying to compile this for all of those who have questions about the 2.2 wheels i've seen several asked including myself and i'm trying to compile an online list from what my lhs showed me
here is a duratrax wheel that will fit [link]http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=22319#ilikepictures[/link] these traxxas will fit [link]http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=4189#ilikepictures[/link] [link]http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=4409[/link] smartech wheels [link]http://www.smartechracing.com/web_2006/product/cars/10341/part_2.php[/link] i like the way they look though they are expensive rc4wd [link]http://rc4wd.com/shop/product_info.php?cPath=75&products_id=1033[/link] some of these hpi's will work [link]http://www.*********.org/car_hpi_truck.htm[/link] tamiya wild dagger wheels will work i cannot find any but heres a link to what they look like [link]http://www2.towerhobbies.com/cgi-bin/wti0005p?&I=TAMC0941&P=PU[/link] i suggest proline tires i just got a pair for my buggy and they are great too bad the rims my brother gave me are all beat up [link]http://www2.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=proline+tires&FVPROFIL=++&search 3=Go[/link] I hope this helps some of yall out feel free to post more |
RE: compatiable 2.2 wheel list
nice work bro
the 2.2 beadlock rims are nice.i want,they would look cool with some imex 2.2 G hawg tires
these fit too i think i'm gonna buy some of these with a set of step pins for sand does anyone know the backspacing on these
rpm revolver [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMSY9&P=M[/link] |
http://www2.towerhobbies.com/cgi-bin...&I=LXKMJ2&P=ML these are 2.8 jato they will fit volcanos they look cool and are great studied tires;)
very nice finds guys, thanks for sharing. Im looking at those jato tires and rims those look sweet. :D
http://www.rcuniverse.com/forum/m_5356950/tm.htm nitro racer has them on look sweet dont they
Yes, I too am getting the Jato wheels and tires, very, very, very [8D]
me three am gettin jato weels make sure you only get the rear weels
All the wheels above will fit only because of the axle diameter and the drive cog is 12mm hex. However many of those wheels will not allow you to proprely install a lock nut on the axle shaft. You guys who have the STX and others who want to put the tires on the Tsunami have to be vary selective. On many wheels with the STX and Tsunami you are SOL unless you want to change your suspension over to the ball type. The problem is when you stick your wheel on the shaft and hex you can't get the nut on because the axle shaft is to short. Its best to go to your LHS and ask them if your could try before your buy. You guys that have the axle held in with the aluminum hex drive can shave the ends of the hex to allow the axle to go threw but make sure the grub locks both still work. One lock works but it comes loose quicker and if you shave to much the wheel hits the hub and locks up. Just don't want any of you guys getting stuck with $15.00 to $50.00 worth of rims you have to try and sell because they didn't fit ;)
ehroof said these would fit and nitro racer has on his tornado
1 Attachment(s)
this is the tsunami with rustler rims, i had to remove some plastic from the back of the rims but you dont notice it that much, rclynx is right, the arms are different on the stx compared to the ball joint suspensions. The tsunami and volcano use the same lower arms so they will work on the volcano too. The jato rims are offset more and will work. The only thing i dont like about the jato rims is that you choice of tires and tire companies is limited, you have alot of choices with the rustler rims.
I guess im lucky, if i order the jato rims for my volcano and they dont work, ill just put them on my jato. Problem solved:D
LOL, I have a pretty big collection of rc so i get to try before i buy
