one way?
Can someone tell me where the one way bearing is for the pull start on SH .28. I pulled off pull starter and there was only nut with attatched shaft. The pull start does not engage and turn motor over but maybe 1 out of ten pulls. Very aggravating. If not the one way ....what could it be?
RE: one way?
clean the one way with some carb cleaner, then clean the shaft it sits on and scuff it up with a little high grit sandpaper and see if this helps you out. i dont have the sh engine and dont see if on redcats site, only for the .27
RE: one way?
the SH m28 p3 is the motor that comes with the hurricane xp pro and hurricane xp. the description on redcat site says it is in both cars. I dont know where the oneway bearing is. it is not in the pullstart housing like most.
RE: one way?
Anyone?
RE: one way?
Hold on I will take my spare one apart, but I think it is set up like the STS engine.
RE: one way?
Does anyone have an answer for me?
RE: one way?
After you take the pull start off there is another plate that needs to come off, the one way is right behind that plate. My XP had the same problem with the one way I tried to clean and such with no luck so I replaced it!
| All times are GMT -8. The time now is 06:28 PM. |
