I finally got my truck running and i ramped it and it ran fine then i got home and tried to start it the next day and when i put it on the ground it wont go, it will keep running but wont go, i have already replaced the clutch spring and the gas tank. I think the engine might have shifted and i will try that but i was going to see if anyone else has had this problem and how to fix it.
RE: ???????
check clutch spring
it mite have came apart |
RE: ???????
Check the slipper clutch. 08013 might have come loose. Alot of people say the gear with the purple nut, but now I have some in silver lol. Tighten that nut if it is loose.
| All times are GMT -8. The time now is 10:35 AM. |
