RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   transmmission for xp (https://www.rcuniverse.com/forum/redcat-racing-support-427/5792798-transmmission-xp.html)
gold_coin 04-30-2007 03:54 PM
ok i bought the xp upgraded all that was said to upgrade but it looks like i didnt have the motor and trans spaced properly, and it ground down the teeth on the spur gear, now im thinking, ive read alot of people seem to like the 2 speed but have also said it is alot more work, should i replace the transmission with a single speed? or should i stick with the 2 speed, if so what spur gears should i get? thanks for the help
ehroof 04-30-2007 05:31 PM
RE: transmmission for xp
you need these gears for the tornado 2 speeds: http://www.clermontmotorsports.com/s...le-gear/Detail and http://www.clermontmotorsports.com/s...le-gear/Detail .
if you want the single speed, get this, i have it in one of my tornado's: http://www.clermontmotorsports.com/s...als/Categories its a direct fit and everything is included to do the swap.
for some reason, the 2 speed dont shift all the time, i have replaced my shifter a few times already on my 2 speed redcats
gold_coin 05-04-2007 09:46 AM
ok thanks, now how do i space the mesh of the gears so this doesnt happen again?
bluecaka69 05-04-2007 10:44 AM
use a piece of paper put it between bell and gear teeth push the 2 together the paper acts as a spacer it should not bind or rip the paper yet there will be a little tention
gold_coin 05-04-2007 11:53 AM
OK cool thanks.
