RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Tight diffs? (https://www.rcuniverse.com/forum/redcat-racing-support-427/5842631-tight-diffs.html)
G*Man 05-11-2007 07:48 PM
Tight diffs?
Im in the process of tearing down my Cane and loctite-ing it all up, and I noticed the diffs arent really smooth when turned by hand. Is this normal when they are new? Seems to be notchy, especially the front and rear diffs, not so much in the center diff.
ehroof 05-11-2007 08:36 PM
RE: Tight diffs?
mine are very easy and mesh nicely, ask in the 1/8 thread and see what they say about theirs.
Chubbysdad 05-11-2007 08:48 PM
RE: Tight diffs?
when they are new I have had the same problem. If your that concerned tear them apart and change out the chinese grease lol...
G*Man 05-11-2007 08:50 PM
RE: Tight diffs?
That stringy icky stuff thats on the ring and pinion is in the diff too? Ok that explains it.
Chubbysdad 05-11-2007 09:34 PM
RE: Tight diffs?
do you mean "chinese slime"? lol
G*Man 05-11-2007 09:42 PM
RE: Tight diffs?
I just figured out the diff locking feature, with tte set screw... too cool!:D
Chubbysdad 05-11-2007 09:45 PM
RE: Tight diffs?
the hurricanes are decent buggies. One of the best handling nitro's on my track. My quake smokes them off the line but they out handle me flyin through the air lol... great jumping nitro's.
mozzzy_2000 05-12-2007 11:51 PM
RE: Tight diffs?
Huh? that set screw just keeps the pins secured in the diff.
G*Man 05-13-2007 12:12 AM
RE: Tight diffs?
There is a grub screw on the diff barrel that if tightented completely locks a one spider gear. hence locking the diff.
AllAboutFunHobbies 05-13-2007 09:15 AM
RE: Tight diffs?
You don't want to do that, yoru going to cause your self some trouble in the long run if one those axles bends and locks up that side yoru going to blow your whole drive train, seen it happen on a buddies GS Storm(same buggy as Hurricane), bent an axle locked up the wheel and transfered the power through the whole rear end and blew the diff and snapped the opposite side drive axle, twisted the rear center axle, stripped the spur gear, blew the center diff and broke the clutch bell. It's cool but it's not worth it.
G*Man 05-13-2007 10:47 AM
RE: Tight diffs?
If I were to use it, I would only ever lock the center diff. Thanks for the heads up.
AllAboutFunHobbies 05-13-2007 05:51 PM
RE: Tight diffs?
ya, alot less to mess up, but to be honnest the center diff on the hurricane distributes the power prety good, I get decent power distribution to both front and rear evenly for the most part.
