RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   engine cutting off problem (https://www.rcuniverse.com/forum/redcat-racing-support-427/6151259-engine-cutting-off-problem.html)
jcervantes11 07-29-2007 04:28 PM
RE: engine cutting off problem
Since ur king of RC :). Ok here is my problem when i steer to my right it stay to the right when it is centered. But if its in the air
it doesn't. And battery is not dead beside server has alot of juice. Can u help me? Here is a vid
http://s193.photobucket.com/albums/z...t=55b4040e.flv
Hope you don't get to dizzy :)
ehroof 07-29-2007 08:03 PM
does it center when you drive? if so your ok, the stock servo's are not high torque, if it stays to one side when you turn and doesnt return to center when driving, you may have a sripped gear inside the servo or maybe your servo saver is set too loose.
jcervantes11 07-29-2007 08:06 PM
Have u watch the vid? No the servo saver is flexing big time, servo is working ok. CHeck out the vid if u have time. Its less then
a min or maybe a min dunno.
ehroof 07-29-2007 08:07 PM
i did check it out, thats why i said maybe the servo saver may be too loose, you may have to tighten it.
jcervantes11 07-29-2007 08:08 PM
http://s193.photobucket.com/albums/z...t=55b4040e.flv aye check it out. maybe i need to tight that servo saver a bit more so it wont flex what happend if i do that? and is it easy?
jcervantes11 07-29-2007 08:10 PM
oh yea i saw it now, do i need to take out the saver out or can i adjested without takeing it out?
ehroof 07-29-2007 08:10 PM
just turn the silver wheel, dont do it too much otherwise you can strip the servo gears.
ehroof 07-29-2007 08:12 PM
clockwise tightens it, counter loosens it
rclynx 07-30-2007 12:31 AM
I've had 2 of them in the past year or so I had to replace because the plastic part of the servo saver would flex to much. One was on a Volcano and the other on a Tsunami[:-]
jcervantes11 07-30-2007 01:04 AM
u could also tight it up too. I grab a lockranch and locked it on the thread then i used a ranch to tight it up now it doesn't move that much. I hope i don't strip my gears on the servos. I was gonna use my airtronics but it doesn't fit well connector doesn't darn. But
its adjestible. I think I was messing with it last time. LOL i don't know!! I'm going to clean my car too sheesh i miss having it clean.
Now its a bit dirty and alot of crap underneath the gears. Black ****. weired
jcervantes11 08-06-2007 05:44 PM
whats better, redcat stock radio or traxxas rustler radio? Whats better stock servo on redcat or traxxas servo?
ehroof 08-06-2007 05:45 PM
traxxas
jamesv 08-18-2007 08:05 PM
i need to know how to set all of the screws on my tsunami. ijust got it given to me and it ran fine, but then i took it and cleaned it and now it does not run write, it will run for 2 sec and then die.
ehroof 08-18-2007 08:25 PM
2 1/2 out on the high, idle scew adjusted until the carb is open 1-2mm or 1/8 inch, and low needle flush with the collar around it.
ehroof 08-18-2007 08:40 PM
jamesv, check this out, it will answer all your question: http://www.rcuniverse.com/forum/m_5399029/tm.htm
