quick question
after i install the clutch spring from traxxas 4146x, and using stock clutchbell. the tsunami is very hard to move, seems like very hard to engage. give it almost full throttle, but it only runs like give a little bit throttle. is the spring too hard to engage? or do i have to change clutchbell to hpi 3 piece too? or i can just use stock steel one. something else wrong with my tsunami
RE: quick question
everyone sleep? :(
RE: quick question
Can you rephrase your question? little hard to understand whats going on.
RE: quick question
Everyone probably is! Don't worry, I am sure that ehroof, clermont or aafh will have an idea for you tomorrow.
RE: quick question
wake up bump,someone plz
RE: quick question
Sounds like it may be slipping, After you run it at full throttle, if you have one use a digital temp gauge to check if it's overly hot, if you don't, then spit test it. if it is, then check the inside of the bell and see if it's wore down a bit. also, is the bell a somewhat snug fit? I mean it should have some play, but very little.
RE: quick question
ORIGINAL: fengraul after i install the clutch spring from traxxas 4146x, and using stock clutchbell. the tsunami is very hard to move, seems like very hard to engage. give it almost full throttle, but it only runs like give a little bit throttle. is the spring too hard to engage? or do i have to change clutchbell to hpi 3 piece too? or i can just use stock steel one. something else wrong with my tsunami sounds to me like your gears are meshed too tightly if i understand what your saying, there should be a little bit of play between the clutch bell and the spur gears. |
RE: quick question
ORIGINAL: ehroof ORIGINAL: fengraul after i install the clutch spring from traxxas 4146x, and using stock clutchbell. the tsunami is very hard to move, seems like very hard to engage. give it almost full throttle, but it only runs like give a little bit throttle. is the spring too hard to engage? or do i have to change clutchbell to hpi 3 piece too? or i can just use stock steel one. something else wrong with my tsunami sounds to me like your gears are meshed too tightly if i understand what your saying, there should be a little bit of play between the clutch bell and the spur gears. |
RE: quick question
on my exhaust pipe which connect to the header and coupler burn, i think it's too hot. i just came back from work and put the hpi clutchbell on, i'll see how it work out tomorrow.
| All times are GMT -8. The time now is 04:42 PM. |
