RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   pull start problems (https://www.rcuniverse.com/forum/redcat-racing-support-427/6309532-pull-start-problems.html)
supersound99ss 08-30-2007 11:27 PM
pull start problems
having problems with the pull start on my xl....its only catching occasionally....is that the one-way bearing going out?
Syclone354 08-30-2007 11:36 PM
RE: pull start problems
clean the one way bearing with some brake cleaner it will fix it right up!
supersound99ss 08-31-2007 11:46 AM
sweet..easy fix then
alpha1one3 08-31-2007 03:10 PM
yeah. I agree with syclone clean it. Then oil it with some WD-40 or you will be hearing loud screaching sounds.
ehroof 08-31-2007 07:02 PM
you may want to sand the shaft a little with 220 sand paper, make sure you clean it off good before you put the one way bearing on, just scuff it up a little, even some coarse steel wool
alpha1one3 09-03-2007 04:19 PM
ehoof. I think I have the same problem with my pull start. Ok here it goes. When my car gets cleaned out and put in garage for the night. Then the next day I can start it on like the Second pull. Then I run it a bit until tank runs out of fuel. I put more fuel while the egines off, then I try to pull and it wont start on the thirs or fifth pull, I have to to pull like 12 times to get it started. I've primed it the same way 15mins ago and its not flooded. It just feels looser then the first time I started it 15mins ago. Would it be because of the hot egine parts expanding and I lost compression and have to wait for it to cool down. Or I have to scuff up the OWB a little since after run oil gives the egine a little restiance.
allenthen831 09-03-2007 04:31 PM
why do u wait till the car runs out of gas why not refuel while the car is on so u dont have to keep turning it on and off
ehroof 09-03-2007 04:49 PM
does it grab when you pull the pullstart? turn the engine over but it just wont start. If thats the case either your running too hot or your engine is shot. Does the compression feel alot less when the engine is warm?
alpha1one3 09-03-2007 04:55 PM
Ok. It starts on the second or third pull when is cold. And when its warm the compression does feel a bit softer and it starts on like the 12th pull. I think its not running hot. I have the HSN and 3 turns open from close setting and the lowspeedneedle flush with the collar. Dont have a thermometer(too expensive). And I did the spit test you were talking about. When I have the egine reving at full throtle to medium throttle at 10mins the spit sizzles less than a second. But idle at 5 mins it evaporates slowly. I think it may be my driving skills or up the needle on the lowspeed and hispeed.
ehroof 09-03-2007 05:15 PM
if it sizzles in less than a second your too hot, richen the hsn a little more, the low speed a little too then see how it starts when warm.
cdextreme 09-03-2007 05:31 PM
If its too hot shoudnt he fatten it up, not lean it out?
ehroof 09-03-2007 05:35 PM
yes, sorry, i dont know why i typed that, wasnt paying attention, meant to say richen
alpha1one3 09-03-2007 05:38 PM
KK. Maybe 1/8 of a turn towards richer on low speed and hi speed needles. I'll try that.
allenthen831 09-03-2007 06:55 PM
forget a pullstart get a starterbox :D i have both a pullstart and a starter box for my kyosho so when i go to the track i use that starter box and when it runs out of batterys i use pullstart [sm=drowning.gif]
Gr8_Outdoorsman 09-04-2007 08:48 AM
My pull rope pulled completely out this weekend on my tornado XL. Can I reinstall the rope, or do I need to replace the assembly? Would it be worth installing an electric starter?
ehroof 09-04-2007 04:30 PM
electric starters are easier, you can try to rebuild your starter, if you go to hpi they have a link to rebuilding one, it cant hurt to try, i would suggest replacing it with an hpi pullstart, the one for the .15 te. if you do a bump box or electric start you will have to have a charged battery in order to use it, not to mention another thing to carry.
