Break In procedures
I'm completely new to nitro trucks and am awaiting my recat volcano SV. I have read about many different break in procedures and methods and was wondering what you guys would suggest along with a good mantance program that i shoud get into to prolong the life of my truck. Thank you guys, Mike
RE: Break In procedures
stick with the break in that comes with the car, easy to do, just make sure you put the piston on the bottom of the engine when you let it cool between tanks and use after run oil when your done with it.
Thank you very much, I kinda planned on doing that but i wanted to ask about the procedure here as well.
My method:
Tank 1: Idle, then drop some after run oil in, and drop the piston to the bottom. Cooldown Tank 2: Repeat of step one Cooldown Tank 3: 3 second passes at 1/4th throttle, then after run oil, and drop the piston. Cooldown Tank 4: Repeat step 3 Cooldown Tank 5: 3 second passes at 1/2 throttle, oil, then drop the piston Cooldown Tank 6: 5 second passes going from no to full throttle, oil, then drop the piston Cooldown Tanks 7-12: Easy driving! This is usually when i replace my plug with a nice mccoy plug After 12 i start leaning out. At about tank 15 I have it fully tuned, and broken in. (I'm very carefull when i break stuff in :]) |
after run oil is used when the car will be sitting. I guess your local hobby shop loves selling you after run oil as much as you are using lol... Whatever works for ya is good I guess.
I basically followed the guide on redcat's web-page. Then tore the heck out of it, still running great for me....Oh and still haven't used any after run oil.;)
| All times are GMT -8. The time now is 07:59 AM. |
