RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   CLEANING (https://www.rcuniverse.com/forum/redcat-racing-support-427/6415077-cleaning.html)
shoota0075 09-26-2007 02:14 AM
CLEANING
what do you guys use for cleaning your trucks/cars ?
giddyuperic 09-26-2007 02:31 AM
RE: CLEANING
Take them apart and clean it with water . I take the servo tray and radio box off and the tires off too. And then clean the car with what ever you want I have been using a elcectric tooth brush and some other small brush's then make sure to dry it off very well with a compressor to blow it off very well. And then use WD40 and spay all of the moving parts. to make sure they get lubed and the WD get's rid of water that's left over. And you can go as far as to spray all of the plastic parts with WD and then wipe them down and it makes them look just like new and I think it makes it easy to clean it the next time. And you can spay the whole thing down with simple green and wash it of with water . There are all kids of ways to clean you ride. it is up to you and how you want it to look .
ehroof 09-26-2007 05:55 AM
RE: CLEANING
i buy wd40 by the gallon, i spray the whole car down and blow it off, looks like brand new when i am done. blow it off before you spray it down to get all the loose stuff off of it. you need a compressor or compressed air.
shoota0075 09-26-2007 07:45 AM
RE: CLEANING
ehroof do u take any of the parts off before u spray the whole car down ?
twomanytoys 09-26-2007 08:48 AM
RE: CLEANING
I also use wd40 and blow it off with compressor. Works great and looks like new. And no I dont take anything off. And when Im done I use a little electric cleaner to spray the brake off.
AllAboutFunHobbies 09-26-2007 09:01 AM
RE: CLEANING
I basiclly do the same thing as Eric once month or once every other month. On a daily bassis I blow mine off with an air compressor. You shouldn't need to take anything off if you are just blowing it off with compressed air.
Chubbysdad 09-26-2007 12:46 PM
RE: CLEANING
Most dirt doesn't just come off with air(at least in florida the sand is sticky lol). I spray the whole car down with wd40 and then blow off with air. Been working great for years.
ehroof 09-26-2007 04:41 PM
RE: CLEANING
leave everything on, spray it down and blow it off, i usually blow it off first then spray it down and blow it off.
vnmsgt 09-26-2007 07:21 PM
RE: CLEANING
I am going to try the wd40. I never used it because I thought it would attract more dirt when you take it out next time. Guess I am thinking wrong. I alway used silicone spray but that does not lube up alot of stuff like wd40 would.
ehroof 09-26-2007 07:34 PM
RE: CLEANING
just make sure you blow it off decently and you will be fine
vnmsgt 09-26-2007 08:13 PM
RE: CLEANING
ORIGINAL: ehroof
I have a pretty big air compressor so I should be ok. I actually am going to try it tomorrow becuase after going to the track on tuesday there were a couple damp spots and my trucks are pretty packed with clay.
ehroof 09-26-2007 08:14 PM
RE: CLEANING
you will be amazed at how good it looks, you let it try overnight and its like a new truck. take some before and after pictures
vnmsgt 09-26-2007 08:23 PM
RE: CLEANING
I try and get some up tomorrow. Do I post pics the same as I did the video?
ehroof 09-26-2007 08:32 PM
RE: CLEANING
yes
vnmsgt 09-27-2007 08:15 PM
RE: CLEANING
1 Attachment(s)
Here is some pics of my hurricane before and after cleaning and using wd40. It was not as dirty as my monsoon but I cleaned that already. Worked pretty good.
ehroof 09-27-2007 08:18 PM
RE: CLEANING
works pretty good huh
vnmsgt 09-27-2007 08:20 PM
RE: CLEANING
Works alot better than the silicone spray I would always use. Thanks for the tip.
twomanytoys 09-27-2007 08:38 PM
RE: CLEANING
For the tough dirt you can soak it over night with wd and spray it off the next day.
vnmsgt 09-27-2007 08:41 PM
RE: CLEANING
So your saying I do not have to use soap and water or still use that like I did today and they the wd40.
ehroof 09-27-2007 08:44 PM
RE: CLEANING
no, just spray down with wd40, wait a while and blow it off, blow it off initially before you spray it down with wd40 though
vnmsgt 09-27-2007 08:47 PM
RE: CLEANING
oh well, next time I will try it that way.
vnmsgt 09-29-2007 08:21 PM
RE: CLEANING
1 Attachment(s)
Here is a good before and after pic
Chubbysdad 09-29-2007 08:23 PM
RE: CLEANING
is it my eyes.. dont look any different? lmao no looks good. why did you take out receiver and servo? To replace? Gunna be there tomorrow? heli's at 7 track racing at 8 lol
vnmsgt 09-29-2007 08:27 PM
RE: CLEANING
Long story short, Went to track with monsoon, sunk monsoon, monsoon full of water, reciever box full of water, steering servo did not like water and flatlined.....
Chubbysdad 09-29-2007 08:28 PM
RE: CLEANING
oh boy... at least it got cleaned :)
