Tornado BB
Hey, i'm wondering if i can switch my 2 speed transmission with a single speed on my tornado bb? If so, can it just be switched out, or will i need extra parts? also, which gear does the single speed use? If i can't then that brings me to my next question. There are 2 gears in the 2 speed on the tonado bb. One is the 47t. Which is the other? Thanks for the help!
RE: Tornado BB
this is what you need to convert a 2 speed to a single speed: http://www.clermontmotorsports.com/s...iff-kit/Detail
RE: Tornado BB
Yes you can switch out your 2 speed transmission for a single speed. All that you would need is one of the 2 single speed transmissions and a single speed clutch bell.
05126 comes with a 44t spur gear http://www.redcatracing.com/parts_se...lt.asp?q=05126 02126 comes with a 42t spur gear. http://www.redcatracing.com/parts_se...lt.asp?q=02126 Single speed clutch bell http://www.redcatracing.com/itemdeta...p?partno=08011 |
RE: Tornado BB
the cluch bell was what i was worried about, I won't be able to switch them because the one i have now won't unscrew, I think i might of put it back on wrong when i changed the clutch spring. So i guess this brings me back to the other question. Anyone know the other gear on the 2 speed set up?
RE: Tornado BB
RE: Tornado BB
Awesome, thanks!
RE: Tornado BB
your welcome bro
| All times are GMT -8. The time now is 04:33 PM. |
