engine problams
the engine on my buggy is weard at idel it smokes like it is acceleraeting. is that normal...
P.S. What is the nedel positioning that you guys use on a day to day basies |
RE: engine problams
Try this turn the HSN Cw til it bottoms out then 3 turns CCW. LSN Flush with the throttle housing.After you do that and set the idle to about a 1mm open start it up and see if its still doing it.
| All times are GMT -8. The time now is 06:17 AM. |
