RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   throttle servo? (https://www.rcuniverse.com/forum/redcat-racing-support-427/6497897-throttle-servo.html)
danny_one 10-16-2007 12:04 PM
throttle servo?
hi guys i have a problem with my tornado bb. i give in gas the throttle wont move but the steering works does, does that mean that i have a bad servo?
Cam_132 10-16-2007 12:13 PM
RE: throttle servo?
i think it is the conection. open the radio box up and check the plug for the th.servo it might have poped out i have had that problam.
danny_one 10-16-2007 02:10 PM
RE: throttle servo?
i opened the box and the conection on the on and off swith were off i tried to connect them back but it still would not work. what should i do?
ehroof 10-16-2007 04:38 PM
RE: throttle servo?
reverse the servo plugs on the reciever, see if the throttle works the steering and the steering works the throttle, if the throttle still doesnt work then the servo is shot.
Chubbysdad 10-17-2007 06:53 AM
RE: throttle servo?
also just a note, there is a little grub screw that goes on the throttle linkage. Sometimes they are too tight and wont allow the servo horn to move. Alot of people tighten them up thinking it is a loose screw but that needs to be loose so it pivots. Just a thought.
danny_one 10-17-2007 02:48 PM
RE: throttle servo?
hi efhroof do you know a good throttle servo that i can get in my local hobby shop?
ehroof 10-17-2007 02:50 PM
RE: throttle servo?
for the throttle get a regular futaba s3003, it should be like $10 or so, its a good servo to use for throttle and brake.
