engine over reving
i just got a new car and it's in the break-in stage but when i start it the engine starts to rev really high. it just started doin' it now but it was running fine the first two tank fulls. any suggestions???
RE: engine over reving
did you mess with the high and low needle yet? did you mess with the idle? once it starts to breakin you will need to lower the idle a bit.
Maybe you adjusted throttle trim on accident?
also make sure the throttle switch settin on your remote hasnt been reversed? Its happen to me and when i started it it almost shot into a wall.
ORIGINAL: ldgasp also make sure the throttle switch settin on your remote hasnt been reversed? Its happen to me and when i started it it almost shot into a wall. LOL....Same here! |
| All times are GMT -8. The time now is 08:17 PM. |
