is it too cold for break in
well i was wondering if anyone could tell me what a safe temp outside is to break in my ultrawide its 32 here now is that too cold or will it be ok as long as i dont hammer on it thank you for any info....
RE: is it too cold for break in
you could try to wrap the cooling head with tin foil to get the temps up but i have 4 cars that need to be broken in and will be waiting for warmer temps, close to 50's.
ORIGINAL: TCB 81 well i was wondering if anyone could tell me what a safe temp outside is to break in my ultrawide its 32 here now is that too cold or will it be ok as long as i dont hammer on it thank you for any info.... Wait until you are at temps around 65-70. Set the carb up accordingly with the manual (they are written up for those temps) and begin break in |
in the prosses of it myself i am on tank 3 it is 31 here and my head temp is just fine just run with the body on. no need to wrap. you got a temp gun?
ORIGINAL: taylor152806 in the prosses of it myself i am on tank 3 it is 31 here and my head temp is just fine just run with the body on. no need to wrap. you got a temp gun? |
yes i have a temp gun i was just worried about damage to motor thanks for the info guys
hint use a peace of somethin behind the throt. to let u run 1/4 then 1/2 something that will not change. just tape it there
my temp is 219 low 232 high but around 220
ORIGINAL: Kemo ORIGINAL: TCB 81 well i was wondering if anyone could tell me what a safe temp outside is to break in my ultrawide its 32 here now is that too cold or will it be ok as long as i dont hammer on it thank you for any info.... Wait until you are at temps around 65-70. Set the carb up accordingly with the manual (they are written up for those temps) and begin break in you have got to be kidding, you think people dont break their cars in in canada or other cooler climates? I would suggest upper 40's to lower 50's but to tell someone to wait until its 70 degrees is just stupid. |
ive been running my buggy all winter here from +5c to -5c with no problems
ORIGINAL: ehroof ORIGINAL: Kemo ORIGINAL: TCB 81 well i was wondering if anyone could tell me what a safe temp outside is to break in my ultrawide its 32 here now is that too cold or will it be ok as long as i dont hammer on it thank you for any info.... Wait until you are at temps around 65-70. Set the carb up accordingly with the manual (they are written up for those temps) and begin break in you have got to be kidding, you think people dont break their cars in in canada or other cooler climates? I would suggest upper 40's to lower 50's but to tell someone to wait until its 70 degrees is just stupid. |
ORIGINAL: taylor152806 hint use a peace of somethin behind the throt. to let u run 1/4 then 1/2 something that will not change. just tape it there |
yes you are right start with something that lets ya do 1/4 then 1/2 then 3/4 then nothing. sorry i was not clear on that
oh ya, i should have thought that you mean that. thats a good idea. you just have to do it in a way that wont make it stick. where did you put the block peace
on the contrler itself so it would not fall off. little duck tape. bingo just cut a little wood block small very small alot of stuff will work just look around
| All times are GMT -8. The time now is 12:13 AM. |
