Break in
started my breakin but was unable to complete in one sitting is this going to cause any engine issues???:eek:
RE: Break in
Nope it should be Okay, just make sure you go from where you left off.
RE: Break in
And ALWAYS make sure you leave the piston at BDC when its cooling down. Make sure you use after run oil when you are done for the day
RE: Break in
in my first tank the truck only hit 125 degrees. it did not get that hot compared to what i heard engines heat up to. is there something wrong with the trucl staying that cool
RE: Break in
try to wrap the head in tin foil to get the temps up a little.
RE: Break in
ORIGINAL: Swingline76 in my first tank the truck only hit 125 degrees. it did not get that hot compared to what i heard engines heat up to. is there something wrong with the trucl staying that cool Good luck Are you going to be racing at FBF? |
RE: Break in
yeah guys, we need to get together, i have a few of us who are going to try to get together on sunday at fbf
RE: Break in
If it wasnt such a long drive Id be there all the time. Im out east though.. One of these days Ill get in there. Is it just on road or is there an off road section too? Where exactly is it at FBF? I used to go there several times a week for work and I never even knew there was an RC track there.
RE: Break in
the on road track is where you first go in the place on the right. there is no offroad we just go further down and bash.
RE: Break in
In on the right? Just past the guard booth?
Im looking at an aerial map now. I never saw the track before. I must have driven past it 1000 times. Where do you park for it? |
RE: Break in
yes, you will see a clearing and a mound of grass, its behind that mound, you park in that parking lot after the booth on the right and walk over to it, you cant really see it from the road.
RE: Break in
How long has the track been there? Im looking at live.com on the aerial map the track is there, on the birds eye view its not. Guess the pictures where taken at different times
RE: Break in
its been there for about 3 years, it was on the ohter side by the aviator but when that was put in they moved it.
| All times are GMT -8. The time now is 01:41 AM. |
