RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Help!! Brushless conversion goes backwards!! (https://www.rcuniverse.com/forum/redcat-racing-support-427/7244469-help-brushless-conversion-goes-backwards.html)
Lordmik 03-18-2008 01:41 PM
Well, the title says it all. I just put in a lrp vector x-11 brushless modified motor and lrp sphere competition esc out of my buddies tc4. Runs fast!!! BACKWARDS!!! LoL I figured out why, but now I need to know if it's fixable. His drive train runs backwards from mine. You turn his driveshaft one way, it goes forward. Turn mine on my Volcano the same way, it's reverse. Any ideas on what I can do for this?? Anyone?? Please?? LOL :(
Michael
ehroof 03-18-2008 01:48 PM
RE: Help!! Brushless conversion goes backwards!!
reverse the black and red wire
bluecaka69 03-18-2008 01:49 PM
you need to switch the wires arooound until it works or else some esc can be programmed to throttle reversing my novak goat did the same thing but it should be an easy fix
Lordmik 03-18-2008 01:52 PM
The only red and black is from the battery to the esc. There's three wires from the esc to motor. Yellow, red, and blue. LoL I'm in over my head I think. I took everything out of the other car, left it all hooked up so I couldn't mess that up, only to find the gears go backwards in the differentials on these.
Michael
ehroof 03-18-2008 01:54 PM
probably red and blue then
twomanytoys 03-18-2008 01:55 PM
Ask Pede kid. He has had the same problem and figured it out. Sounds like he just switched the wired on teh motor.
Lordmik 03-18-2008 01:57 PM
Thanks guys, I'll pm him and let you know how it goes. This may help. The red goes to terminal mot c, the yellow to mot b, and the blue to mot A on the motor. I won't burn anything up or damage anything swapping wires around?
Michael
pede_187 03-18-2008 02:43 PM
yeah, switch any two wires
Lordmik 03-18-2008 04:21 PM
Well, I talked to the guys at team associated in cali, since this is a sensored system there's no way to get it to run the opposite direction. [&o] So I guess I'm outta luck with going brushless. Anyone interested in this LRP motor & esc? LoL From what I hear it's pretty good. As long as your diffs are geared the right way. LoL
ehroof 03-18-2008 04:46 PM
wow, that stinks bro, did you try to reverse the wires?
jumpanddrop 03-18-2008 04:52 PM
ORIGINAL: Lordmik
modd the car so you put the motor on the other side of the spur gear:D
Lordmik 03-18-2008 05:10 PM
I thought about that. LoL Instead I listed it on the classifieds here. Maybe it'll sell. They're pretty expensive new.
Redcat_Mike 03-18-2008 05:15 PM
LordMik, i sent you a pm
Lordmik 03-18-2008 05:22 PM
Got it. Thanks mike.
twomanytoys 03-18-2008 09:03 PM
You should be able to switch the wires to run a different way. Motors are designed to run either way.
5lagd 03-18-2008 09:42 PM
cant you just switch your throttle on your remote?
Lordmik 03-18-2008 09:46 PM
Unfortunately, no. This motor will not run in the opposite direction.
Michael
5lagd 03-18-2008 09:54 PM
ORIGINAL: Lordmik
Michael
lol, was worth a shot.
Redharris 03-18-2008 10:31 PM
How about ya reverse mount the body. Then you'll have a Rear Steer car. IMAGINE how Sharp you will be able to carve a corner!:D
UUhhhmm.....Sorry.....just trying to add a bit of Humor to a Bummer of a situation.
Seriously tho. I cannot see how such a simple Motor cannot be made to turn in the opposite Direction.....I has reverse,,,,,right?
Perhaps the limitation is the ESC. Maybe the sensor will nor operate correctly with the motor running in an opposite direction.
Perhaps a new ESC. I think I read in a RC Mag that you could run a Sensored Moter with an ESC that has no Sensor. But you cannot use a SENSORED ESC to run a Non sensored motor. Does that make sense to you Electric RC folks?
