RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   dynamite tuned pipe (https://www.rcuniverse.com/forum/redcat-racing-support-427/7598880-dynamite-tuned-pipe.html)
harley75 06-09-2008 01:21 PM
dynamite tuned pipe
I just got this tuned pipe dynamite DYN-6605 now the thing is the hook up for the pressure hole will be on the bottom due to the motor is monuted on the right side on the tornado BB is there anyway i still can use this pipe on this engine
5lagd 06-09-2008 02:58 PM
RE: dynamite tuned pipe
use a longer piece of fuel tubing.
harley75 06-09-2008 03:11 PM
well the pressure hole should be on top or side not the bottom
Cam_132 06-09-2008 03:24 PM
1 Attachment(s)
it should not be on the botem becouse it would make the unbernt oil go back into the tank and contaminate it. if you use a stop it will work.
a stop workes like a car airbox. it will suck in watter and air then it will seperate it.
Like this
the lighter gases rise to the top and get putinto the tank
and the heaver oil gets put in the stop.
harley75 06-09-2008 03:26 PM
what is a stop never heard of it
el_tonto 06-09-2008 03:58 PM
Do you mean DYN-6609? 6605 is the header, not the pipe.
If it is 6609 then it looks like the two halfs of the pipe can be removed from each other - the exhaust tip can probably be spun 180° relative to the body.
harley75 06-09-2008 04:58 PM
It's a 6605 comp tuned pipe it's a older one check your numbers it comes up DYN-6605 comp tuned pipe
AllAboutFunHobbies 06-09-2008 09:45 PM
Do you have a picture of it mounted on your car?
harley75 06-10-2008 04:27 AM
i didn't mount it yet because it's a left side pipe and the pressure hole would be on the bottom thinking of pluging the hole with a grub screw and high temp RTV and drilling another hole.Would it be ok to plug the hole and redrill
