throttle arm
When i have my body on my tornadoBB seems the pull start up on the throttle arm and it keeps the idle up would a quick fix bending the arm a little work.Does anyone have a better idea
RE: throttle arm
Wha? You mean the throttle servo horn is hitting the pull start?
RE: throttle arm
arm with the spring on it when i go to brake the pull start gets under it and it hangs up
RE: throttle arm
use a ziptie and tie it to the shock mount
RE: throttle arm
thats work great
| All times are GMT -8. The time now is 05:46 AM. |
