Deans Connector Questions
I would like to convert an NiMH 8.4 volt 4500mah battery to a deans connector. I'm wondering if their is even enough amps to require a deans connector. Also would a NiMH 9.6volt 4500mah battery require deans or not. If so could you suggest a one that would work good for me thanks, I'm planing on using these batterys in my volcano epx pro. Also If I do change these batterys to deans wont I need to change my chargers to deans?
RE: Deans Connector Questions
The deans plugs are to reduce heat from cheap connectors since they have a very low resistance. Being that there is less resistance with a Deans plug as compared to molex, powerpoles, and trx connectors, there is also less of a current loss along with less of a voltage drop.
You'll need a male end for your charger and female plugs for your packs. Depending on your esc and motor setup, its probably best that you just opt for the deans connectors. Since the days of molex were also the days of 500 - 1500 mAh packs with mabuchi 540 motors, they should pretty much be thinning out here in the future. Molex was great back in the day, but they simply don't hold up to the current that hot motors can pull today... AND the packs have a way higher capacity, many people end up with molex connector meltdowns! |
ORIGINAL: Kemo The deans plugs are to reduce heat from cheap connectors since they have a very low resistance. Being that there is less resistance with a Deans plug as compared to molex, powerpoles, and trx connectors, there is also less of a current loss along with less of a voltage drop. You'll need a male end for your charger and female plugs for your packs. Depending on your esc and motor setup, its probably best that you just opt for the deans connectors. Since the days of molex were also the days of 500 - 1500 mAh packs with mabuchi 540 motors, they should pretty much be thinning out here in the future. Molex was great back in the day, but they simply don't hold up to the current that hot motors can pull today... AND the packs have a way higher capacity, many people end up with molex connector meltdowns! |
...they are both zero-loss connectors That's not to say the aren't any good, of course. All of those modern connecters listed above will be better than the older Molex/Tamiya connectors. And yes, you'll need to change your charger, OR simply make an adapter using the old Molex plugs that you cut off your battery pack! (by the way, cut the old connector off one lead at a time! If you cut both you'll probably short the battery using the cutters!) |
ORIGINAL: pede_187 ORIGINAL: Kemo The deans plugs are to reduce heat from cheap connectors since they have a very low resistance. Being that there is less resistance with a Deans plug as compared to molex, powerpoles, and trx connectors, there is also less of a current loss along with less of a voltage drop. You'll need a male end for your charger and female plugs for your packs. Depending on your esc and motor setup, its probably best that you just opt for the deans connectors. Since the days of molex were also the days of 500 - 1500 mAh packs with mabuchi 540 motors, they should pretty much be thinning out here in the future. Molex was great back in the day, but they simply don't hold up to the current that hot motors can pull today... AND the packs have a way higher capacity, many people end up with molex connector meltdowns! |
| All times are GMT -8. The time now is 05:43 PM. |
