RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Which Pull Start? (https://www.rcuniverse.com/forum/redcat-racing-support-427/8480164-pull-start.html)
Geoff78 02-15-2009 05:58 PM
Which Pull Start?
The cord broke on my pull start for my VX-18. After taking it apart, the spring came out and I don't have the patience to fix it. I looked on the Redcat site, and it has two, one for a 1 1/4 inch spacing and a 1 inch spacing. Normally I measure center of hole to center of hole, but when I do that I am not getting either of those measurements exactly. Can anyone simplify this for me and give a link to one that will work for sure?
perhamrocks 02-15-2009 06:59 PM
RE: Which Pull Start?
if you don't have the paitience for fixing it you better get a roto starter, but it's really not that hard to get the spring back in. just put the end into the casing and start wrapping the coil inside of the casing, instead of trying to wrap the coil tight enough, then trying to put it into the plastic casing
