RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   clutch problems (https://www.rcuniverse.com/forum/redcat-racing-support-427/8626798-clutch-problems.html)
neyou86 03-28-2009 06:57 PM
clutch problems
when i pull on my pull start the clutch is engaged what is wrong?
and if something is broken what parts fit on it
1972roadrunner 03-28-2009 09:10 PM
RE: clutch problems
the spring most likely broke. it might be fixable, but most likely you'll need to replace it.
neyou86 03-29-2009 07:27 AM
RE: clutch problems
what spring works?
neyou86 03-29-2009 02:20 PM
RE: clutch problems
well i took it apart and the shoes are a little worn and the spring was broke and the peg that is on then flywheel that holds the shoes is broken
what parts can i use to replace these
rclynx 03-29-2009 07:51 PM
RE: clutch problems
Time for a new flywheel and clutch it sounds like. If you can go with M.I.P. very reliable clutch [&o]
neyou86 03-29-2009 09:09 PM
RE: clutch problems
what mip flywheel fits
