help?
So its my first nitro truck and i just got it all ready to go and got it started and it was idleing super high so i turned it down and it killed it. started it again and it bogged out and now it wont start at all i tried messing with the idle screw but no such luck it seems slightly easier to pull as well any ideas?
RE: help?
try adjusting ur throttle trim on ur controller
nitro engines have high rpms so just as long as ur wheels arent moving u will be good |
RE: help?
What car is it?
RE: help?
sounds like ur low speed needle is too rich. lean it out and that should also help ur idle along with the idle screw
| All times are GMT -8. The time now is 09:28 PM. |
