RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Engine problems (https://www.rcuniverse.com/forum/redcat-racing-support-427/9109849-engine-problems.html)
BigDave09 09-20-2009 12:03 PM
Engine problems
well my engine ceased up on me the other day and i took it apart and the piston rod was broke and now im fixing it and can't get the sleeve out any suggestion or tips would help
AllAboutFunHobbies 09-20-2009 01:02 PM
RE: Engine problems
Stick a zip tie through the exhaust port and push up with the piston.
BigDave09 09-20-2009 01:10 PM
RE: Engine problems
i couldn't get it out wit pliers
BigDave09 09-20-2009 02:01 PM
RE: Engine problems
when the engine blows is it the piston and sleeve that go bad or is it the block itself
chevyderek72 09-20-2009 04:16 PM
RE: Engine problems
Depends, anything can go, i got a few blown big blocks in a trade and in one the block cracked, in another the rod broke.
BigDave09 09-20-2009 04:43 PM
RE: Engine problems
well how can you tell if the piston and sleeve is bad or not
UrcHobby 09-20-2009 05:24 PM
RE: Engine problems
99% of the time when the connecting rod breaks the crank comes around and the crank pin hits the broken rod and mashes the bottom of the sleeve and eggs it in the bore, your best bet if you broke the rod is to replace the entire motor. Reason why I say this is because there is a very high chance that there is more wrong then just a broken rod ie: bad bearings, crank might have damage now also there can be a crack in the block that can cause a air leak that you might not even see. Sorry about the bad news. But you can always use Redcats Lifetime Engine Replacement Program. It can be found here http://www.redcatracing.com/informat...imeengine.html
robriley 09-20-2009 07:08 PM
RE: Engine problems
i wouldn't even bother wasting the time to take it apart. i'd just send it in for a new replacement motor.
you can't beat the engine replacement program.
BigDave09 09-20-2009 08:25 PM
RE: Engine problems
i bought my motor from rufaster(mike) can i still do the replacement plan
UrcHobby 09-20-2009 08:56 PM
RE: Engine problems
Yes you just need to have a copy of your original invoice.
