red cat exp pro esc problems
ok i just bought a redcat exp vortexpro when i nail the throttle the reciever turns off but it i go through it easy it it goes to full throttle fine. it also glitches in reverse any ideas would be helpful. it did it with the factory radio and my spectrum im really confused here.
RE: red cat exp pro esc problems
sounds like voltage cut off. even tho you think the batt is fully charged it may have to go thru a few cycles. is it the stock bat? if it is go lipo!!! you WILL NOT go back to Nimh... go to urchobby.com cool people there
you can get higher quality lipos for a LOT less than that at www.hobbyking.com
