S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
TA-152 foam build
Old 12-15-2011, 09:57 PM
cosmogod
Default TA-152 foam build
Well Iunearthed an old post with the same theme but the user dimadee is not reachable, so here is a question for all.
I wanted to build a TA-152 foam plane (with proper fuselage and wings.. not profile plane) to be used with a .19 engine.
can any body give me deatils like
wingspan ( i am guessing 50" )
length,
ideal weight,
what foam is to be used
and how do i construct the wing and insert wood/plastic ribs to make it rigid and strong?
thanks,
cosmo
P.S:i will be useing 4 x 325HB servos nad ar600 receiver
Old 01-13-2012, 09:43 AM
OIL CAN DAN
Default RE: TA-152 foam build
Are You going to cut the foam Yourself using a hot wire set up? I made one of these wire setups using a dimmer switch and piano wire strung between wooden dowels and it worked excellent. I had gotten the info on the construction of it from one of the members on this forum years ago so if You can't locate the plans let me know and I'll do My best to show You how. Dan
Old 01-23-2012, 10:19 AM
cosmogod
ORIGINAL: OIL CAN DAN
Thanks Dan!!
Ifound the plan... it is made by Dan Paluzzi. Tell me if you're using a different set of plans. would love to see the difference.
-cosmo
Old 02-24-2012, 01:52 PM
icerinkdad
Do a google search on foam wing cutting. There is a lot available there. If that isnt enough my son sells a video I did on cutting foam thru his website (you will come across it when you view the 8 minute segment posted for free). It isnt difficult but will take some practice. How much experience do you have with RC and model building in general?
Old 02-24-2012, 08:08 PM
cosmogod
Oh! thanks, I have built a few spads , and did foam carving in architecture classes. I got a foam cutting rig made for me since my last post, but thanks for helping.
keep em flying,
cosmo
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
